[gdal-dev] OGR CSV oddity
Scott
public at postholer.com
Sat Jun 17 08:54:44 PDT 2023
If I select a single column from a table, the header column name has a
trailing comma. If I select more than 1 column it does not. Example:
ogr2ogr -f CSV -sql "select col1 from table limit 1" /vsistdout/ source.gpkg
Output:
col1,
123
Tested on 3.5.1 and 3.7
I've tried this on various column data types with the same result.
Pseudo suggestion:
header += header.length ? "," + colname : colname
www.postholer.com
