[gdal-dev] [EXTERNAL] [BULK] OSX 13.4 (M1 Pro) troubles using GDAL
Paul Harwood runette at gmail.com
Wed Jun 21 09:37:52 PDT 2023
To state the (I hope) obvious - it must be a problem with your installation
and not a general problem with GDAL on Mac - I just tried it on a fresh
installation and it worked.
However - I used Conda as the virtual environment and not Brew/Venv/Pip. I
find it much more consistent and easier ...
On Wed, 21 Jun 2023 at 17:05, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS
AND APPLICATIONS INC] via gdal-dev <gdal-dev at lists.osgeo.org> wrote:
> I checked which functions that were being exported from
> python3.11/site-packages/osgeo/_gdal.cpython-311-darwin.so
> And found a few IO-esque functions, including _GDALReadBlock and
> _Band_ReadRaster.  Calling these via the standard bindings work.  Must be
> how rasterio is operating under the hood.
> This import line is ultimately what fails for me in
> test_env/lib/python3.11/site-packages/osgeo/gdal_array.py
> *# Import the low-level C/C++ module*
> if __package__ or "." in __name__:
>     from . import _gdal_array
> I see no _*gdal*_array file of any kind in /osgeo/.  Only _gdal,
> _gdalconst, _gnm, _ogr, and _osr .so files and the python wrappers.
> I don’t know where these .so files are sourced from / generated (brew’s
> installation, pip?).
> Hopefully this helped clarify the problem..
> Jesse
> *From: *gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of "Meyer,
> Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev" <
> *Reply-To: *"Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
> APPLICATIONS INC]" <jesse.r.meyer at nasa.gov>
> *Date: *Tuesday, June 20, 2023 at 4:44 PM
> *To: *"gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> *Subject: *[EXTERNAL] [BULK] [gdal-dev] OSX 13.4 (M1 Pro) troubles using
> GDAL
> Hi,
> My GDAL installation procedure looks like:
> Install python 3.11.4 from the official site
> brew install gdal (this grabbed numpy v1.25, and a number of other
> pre-reqs, and installs 3.6.4)
> python -m venv test_env
> // activate test_env //
> pip install numpy (installs v1.25)
> pip install gdal==3.6.4 (brew does not yet house 3.7)
> This appears to work fine at first.  I can manipulate gdal datasets up
> until I use band.ReadAsArray().  Python throws an exception `cannot import
> name '_gdal_array' from 'osgeo`.
> Should this have worked?  Stack Overflow has a few instances of this
> problem and they all point to incorrect install orders, or various software
> environments interacting poorly.  But I don’t think I’m making those
> mistakes.
> What causes my head to spin is that, I installed rasterio, and the ‘read’
> function works!  It must be via a different mechanism, but I wasn’t able to
> follow the code architecture in Github to see how they pull it off.
> Any advice?  Thanks --
> Jesse
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230621/faac64bf/attachment-0001.htm>
