[gdal-dev] 3D extent
B. De Mezzo
benoit.de.mezzo at oslandia.com
Fri Jun 23 02:14:00 PDT 2023
I was looking for a solution to retrieve a 3D extent (in my case from a
gpkg). Currently, the OGR_L_GetExtent function uses an OGREnvelope and
when I pass a OGREnvelope3D parameter, it does not fill the Z fields.
What should be the best approach to the minZ and maxZ for a layer?
Regards.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230623/7d8ed618/attachment.htm>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230623/7d8ed618/attachment.sig>
