[gdal-dev] 3D extent
Even Rouault even.rouault at spatialys.com
Fri Jun 23 02:45:48 PDT 2023
(re-adding the list)
Le 23/06/2023 à 11:34, B. De Mezzo a écrit :
> Thanks!
> I will try this sql request to handle this specific case.
> Do you think it could be possible to have a OGR_L_GetExtent3D()
> function which returns, as a default implementation, the
> OGR_L_GetExtent() result and with 0.0 (or NaN) for the Z coordinates?
> Future works can re-implement the OGR_L_GetExtent3D driver function to
> fit the real data.
That's technically possible, but at bit odd. I'd say that while at it,
it would be much better to have a default generic implementation in the
base OGRLayer class that does the iteration, just like the 2D version at
https://github.com/OSGeo/gdal/blob/master/ogr/ogrsf_frmts/generic/ogrlayer.cpp#L230
. Driver specializations could indeed come afterwards
> Benoit.
> Le 23/06/2023 à 11:25, Even Rouault a écrit :
>> Benoit,
>> Indeed OGR_L_GetExtent() will never fill the Z fields, since it has
>> no idea they are there. So a 3D specific function would be needed.
>> But in the case of GeoPackage, as many/most other formats, layer
>> extent metadata doesn't include the Z component either. The generic
>> option is to iterate over all features and use OGR_G_GetEnvelope3D()
>> on their geometry.
>> In the specific case of GeoPackage, you could also issue a
>> ExecuteSQL("SELECT MIN(ST_MinZ(geometry_column_name)),
>> MAX(ST_MaxZ(geometry_column_name)) FROM layer_name") which should be
>> faster on big layers
>> Even
>> Le 23/06/2023 à 11:14, B. De Mezzo a écrit :
>>> Hi,
>>> I was looking for a solution to retrieve a 3D extent (in my case
>>> from a gpkg). Currently, the OGR_L_GetExtent function uses an
>>> OGREnvelope and when I pass a OGREnvelope3D parameter, it does not
>>> fill the Z fields.
>>> What should be the best approach to the minZ and maxZ for a layer?
>>> Regards.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230623/d653ec3b/attachment.htm>
