[gdal-dev] ogr2ogr sqlite dialect and fgb format
Patrick Young patrick.mckendree.young at gmail.com
Wed Jun 28 08:50:55 PDT 2023
Here's the CREATE TABLE from 3.4:
OGR2SQLITE: sqlite3_declare_vtab(CREATE TABLE "roadbed"("SOURCE_ID"
FLOAT,"FEATURE_CODE" INTEGER_INT16,"SUB_FEATURE_CODE" INTEGER,"STATUS"
VARCHAR(16),"SHAPE_Length" FLOAT,"SHAPE_Area" FLOAT,OGR_STYLE VARCHAR
HIDDEN,"SHAPE" BLOB_MULTIPOLYGON_XY_2263, OGR_NATIVE_DATA VARCH
AR, OGR_NATIVE_MEDIA_TYPE VARCHAR))
In the 3.5+ versions, sqlite is angry about the
INTEGER_INT16_BEGIN_DOMAIN_NAME_64526F6164626564_END_DOMAIN_NAME
On Wed, Jun 28, 2023 at 9:18 AM Patrick Young <
patrick.mckendree.young at gmail.com> wrote:
> Hi,
> I'm playing around with the gdb dataset
> https://data.cityofnewyork.us/Transportation/NYC-Planimetrics/wt4d-p43d
> and getting errors starting with gdal 3.5 when I try to use the sqlite
> dialect:
> ogr2ogr -f GeoJSONSeq -sql "select shape from roadbed where source_id =
> 13350003311" -dialect sqlite /vsistdout/
> NYC_DoITT_Planimetric_OpenData.gdb.zip
> ERROR 6: Unsupported field type for range domain: esriFieldTypeDate
> ERROR 1: Cannot create virtual table for layer 'roadbed' : CREATE VIRTUAL:
> invalid SQL statement : CREATE TABLE "roadbed"("SOURCE_ID"
> INTEGER_INT16_BEGIN_DOMAIN_NAME_64526F6164626564_END_DOMAIN_NAME,"SUB_FEATURE_CODE"
> INTEGER,"STATUS"
> VARCHAR(16)_BEGIN_DOMAIN_NAME_645374617475735F31_END_DOMAIN_NAME,"SHAPE_Length"
> FLOAT,"SHAPE_Area" FLOAT,OGR_STYLE VARCHAR HIDDEN,"SHAPE"
> BLOB_MULTIPOLYGON_XY_2263, OGR_NATIVE_DATA VARCHAR, OGR_NATIVE_MEDIA_TYPE
> VARCHAR)
> ERROR 1: In ExecuteSQL(): sqlite3_prepare_v2(select shape from roadbed
> where source_id = 13350003311):
>   no such table: roadbed
> This command works in GDAL 3.4 (and also works with the ogr sql dialect);
> I was wanting to use the sqlite dialect so that i can use CASE statements.
> Is this a bug or expected?
> Thanks,
> Patrick
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230628/3b4e92cc/attachment.htm>
