[gdal-dev] Converting VPF vector set into shapefile (under Windows environment)
Philippe Ghesquiere philippe.ghesquiere at airbus.com
Thu Jun 29 04:20:18 PDT 2023
Hi Jérome,
Thanks for the hint : it does work, despites the warning messages
Philippe
On Thu, Jun 29, 2023 at 11:45 AM Jerome Siot <jerome.siot at mytimezero.com>
wrote:
> Hello,
> Replacing "\" by "/" gives result with error. (windows 10)
> jerome.siot at WORK C:\Users\jerome.siot
> $ ogrinfo gltp:/vrf/C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash
> vpf_open_table: error opening
> <C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash/libref/fcs>
> <C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash/elev/fcs>
> <C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash/hydro/fcs>
> <C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash/ind/fcs>
> <C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash/phys/fcs>
> <C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash/pop/fcs>
> <C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash/trans/fcs>
> <C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash/util/fcs>
> <C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash/veg/fcs>
> INFO: Open of
> `gltp:/vrf/C:/git/gdal/autotest/ogr/data/vm2alv2_texash/texash'
>       using driver `OGR_OGDI' successful.
> 1: tileref at tileref(*)_area (Polygon)
> 2: tilereft at tileref(*)_text (Point)
> 3: markersp at bnd(*)_point (Point)
> 4: polbndl at bnd(*)_line (Line String)
> 5: polbnda at bnd(*)_area (Polygon)
> 6: bndtxt at bnd(*)_text (Point)
> Regards, Jérome
> *De :* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *De la part de*
> Philippe Ghesquiere via gdal-dev
> *Envoyé :* Wednesday, June 28, 2023 6:57 PM
> *À :* gdal-dev at lists.osgeo.org
> *Objet :* [gdal-dev] Converting VPF vector set into shapefile (under
> Dear all,
> I would like to convert a VPF vector set ( OGDI driver
> <https://gdal.org/drivers/vector/ogdi.html>  ) into shapefile format.
> My environment is  as follow:
>    - windows 10
>    - GDAL environment installed with QGIS 3.26.0 : *GDAL 3.5.0, released
>    2022/05/10*
>    - the OGDI driver is available
>    ogrinfo --format ogr_ogdi
>    Format Details:
>      Short Name: OGR_OGDI
>      Long Name: OGDI Vectors (VPF, VMAP, DCW)
>      Supports: Vector
>      Help Topic: drivers/vector/ogdi.html
>      Supports: Open() - Open existing dataset.
>      Supports: Multiple vector layers.
> To make sure I have a supported database, I downloaded the
> gdalautotest suite.
> After reading the OGDI driver <https://gdal.org/drivers/vector/ogdi.html>
> page, I modified the example for a  windows environment. I tried the
> following command
> ogrinfo
> gltp:/vrf/C:\Download\GDAL\gdalautotest-3.6.4\ogr\data\vm2alv2_texash\texash
> I observe :
>    - nothing happens (no warning or error message)
>    - activating debug mode does not give any extra information
> As mentioned in the  OGDI driver
> <https://gdal.org/drivers/vector/ogdi.html> page, the '*texash/*'
> directory is at the same level as the *dht *and *lat *files.
> Do you have any idea for a correct "windows-like" path I should use ?
> Thanks
> Philippe
> The information in this e-mail is confidential. The contents may not be
> disclosed or used by anyone other than the addressee. Access to this e-mail
> by anyone else is unauthorised.
> If you are not the intended recipient, please notify Airbus immediately
> and delete this e-mail.
> Airbus cannot accept any responsibility for the accuracy or completeness
> of this e-mail as it has been sent over public networks. If you have any
> concerns over the content of this message or its Accuracy or Integrity,
> please contact Airbus immediately.
> All outgoing e-mails from Airbus are checked using regularly updated virus
> scanning software but you should take whatever measures you deem to be
> appropriate to ensure that this message and any attachments are virus free.
The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.
If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.
Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.
All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230629/5c8c07bf/attachment.htm>
