[gdal-dev] Convex hull with holes
Joaquim Manuel Freire Luís
jluis at ualg.pt
Fri Mar 3 07:31:27 PST 2023
I do that type of things with GMT’s mask module (-D option)
https://docs.generic-mapping-tools.org/latest/mask.html
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Paul Meems
Sent: Friday, March 3, 2023 2:47 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Convex hull with holes
Thanks Jukka for your reply.
I understand it is hard.
In my case, I have a lot of data points making your edge case not a problem for me.
The data points are collected driving over a field with 1 or more sensors.
The result can be something like this:
[cid:image001.png at 01D94DE5.376CB160]
The red dots are the data points and I manually created the black border and added a small buffer.
The red dots are transformed into polygons using inverse distance and afterward, I need to 'blank' the data using the black border.
I can automate all steps except for creating this field border.
I'm also struggling to get a proper name for my needs, making it harder to Google for a solution.
'Convex hull' is not correct. What would be a more appropriate name?
Regards,
Paul
Op vr 3 mrt. 2023 om 14:13 schreef Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>:
So you have an uncategorized bunch of points and you wish to have an algorithm that recognizes outer and inner rings automatically? I fear that is not as easy as it may appear. Have a look at the annexed image with two polygons having the same vertices. How could an algorithm know which interpretation is correct? In this simple case you could make a convex hull, delete the vertices which were consumed for the outer ring, and create a new ring from the remaining points, but generally it will not work if there are two holes, for example.
If the points come from a GPX device, make the application to record indexes for both the points and the rings “ring1-point1, ring1-point2---ring2-point1,ring2-point2” and construct the polygon ring by ring.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta Paul Meems
Lähetetty: perjantai 3. maaliskuuta 2023 14.52
Vastaanottaja: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] Convex hull with holes
How can I algorithmically create a parcel border that accounts for islands or holes within the parcel based on a list of coordinates?
While GDAL+GEOS has a Convex hull method, it only identifies the outer border.
Has GDAL+GEOS a method that I can use to detect inner holes as well, such as in a donut-shaped field?
The output can be json or shapefile, that doesn't matter.
Thanks,
Paul Meems
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230303/7d53b516/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230303/7d53b516/attachment-0001.png>
