[gdal-dev] getting SRS units from GetAttrValue("UNIT", 0)?
Edzer Pebesma
edzer.pebesma at uni-muenster.de
Tue Mar 7 08:08:43 PST 2023
Thanks, Even!
I was after the units of the horizontal coordinates; GetLinearUnits()
returns "unknown" for EPSG:4326 and, according to the docs returns the
units of the vertical coordinate in 3D CRS (didn't check). So what I now
use is GetAttrValue("UNIT", 0) (which returns "degree" for EPSG:4326"),
and if that returns NULL, use GetLinearUnit(&unit) if its value differs
from "unknown".
Many regards, and thanks for the example code,
On 07/03/2023 12:46, Even Rouault wrote:
> Edzer,
> if you change your code to use GetLinearUnits() it will work:
> #include <gdal.h>
> #include <gdal_priv.h>
> #include <iostream>
> int main()
> OGRSpatialReference *srs = new OGRSpatialReference;
> int epsg = 3031;
> srs->importFromEPSG(epsg);
> const char* unit = "";
> srs->GetLinearUnits(&unit);
> std::cout << epsg << ":" << unit << std::endl;
> const char *proj4s = "+proj=eqearth";
> srs->importFromProj4(proj4s);
> unit = "";
> std::cout << proj4s << ":" << unit << std::endl;
> return 0;
> If you wonder why GetAttrValue("UNIT", 0) works sometimes and not not
> for others, this is a bit tricky. When querying WKT nodes directly like
> with GetAttrValue(), GDAL works internally with a WKT1 representation,
> for backward compatibility as a lot of code inside GDAL (and potentially
> outside) queries with WKT1 node names. The issue here is that eqearth is
> a new projection method that didn't exist in GDAL <= 2.4, so GDAL
> fallbacks to WKT2 representation, and it's not the UNIT keyword in WKT2
> but LENGTHUNIT.
> Using GetLinearUnits() is more robust, as independent from the WKT1/WKT2
> representation
> Even
> Le 07/03/2023 à 11:38, Edzer Pebesma a écrit :
>> I switched getting coordinate units from the expanded proj4string
>> representation to GetAttrValue("UNIT", 0), but failed; try
>> #include <gdal.h>
>> #include <iostream>
>> int main()
>> int epsg = 3031;
>> std::cout << epsg << ":" << srs->GetAttrValue("UNIT",0) << std::endl;
>> const char *u = srs->GetAttrValue("UNIT",0);
>> std::cout << proj4s << ":" << (u ? u : "NULL") << std::endl;
>> return 0;
>> which gives
>> 3031:metre
>> +proj=eqearth:NULL
>> whereas the proj4string expansion of "+proj=eqearth" is "+proj=eqearth
>> +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs", so has the units.
>> What do I miss here? What is the recommended way to get coordinate units?
Edzer Pebesma
Institute for Geoinformatics
Heisenbergstrasse 2, 48151 Muenster, Germany
Phone: +49 251 8333081
