[gdal-dev] Using GDAL with opencv in C++ there is errors under windows
Raivo Rebane
raivo at r-systems.ee
Tue Mar 7 09:07:34 PST 2023
Hi
There was problem in libraries.
VIsual Studio seeks firstly PostGIS libraries what is older ones
Now I set Firstly seek from separately installed GDAL libraries.
But conflict in twice installed PROJ packages exist.
So, I cant use PROJ package functions.
Can anybody helps me ?
Regards
Raivo
On 07.03.23 11:28, Raivo Rebane wrote:
> I use Visual Studio and there is defined for linking following libraries:
> gdal.lib
> opencv_calib3d460d.lib
> opencv_core460d.lib
> opencv_dnn460d.lib
> opencv_features2d460d.lib
> opencv_flann460d.lib
> opencv_gapi460d.lib
> opencv_highgui460d.lib
> opencv_imgcodecs460d.lib
> opencv_imgproc460d.lib
> opencv_ml460d.lib
> opencv_objdetect460d.lib
> opencv_photo460d.lib
> opencv_stitching460d.lib
> opencv_video460d.lib
> opencv_videoio460d.lib
> as I use OpenCV.
> What library is neede for linker ?
> As a matter of fact this source compiles, links and runs without
> problems day after yesterday
> Regards
> Raivo
> On 07.03.23 10:46, Mateusz Loskot wrote:
>> On Tue, 7 Mar 2023 at 09:32, Raivo Rebane <raivo at r-systems.ee> wrote:
>>> I minimized the program :
>>> #include <gdal.h>
>>> #include <gdal_priv.h>
>>> #include <iostream>
>>> #include <conio.h>
>>> int main()
>>> GDALAllRegister();
>>> GDALDataset* dataset =
>>> static_cast<GDALDataset*>(GDALOpen("634632_2012_tava.tiff",
>>> GA_ReadOnly));
>>> GDALClose(dataset);
>>> return 0;
>> The errors like
>> LNK2001 unresolved external symbol
>> typically mean a program is not being linked against required libraries.
>> You need to refer to documentation of the compilation toolset you are
>> using
>> in order to learn how to configure build of your program properly,
>> how to pass gdal.lib to its linker, etc.
>> If you are using CMake, you can follow this recommendation
>> https://gdal.org/development/cmake.html
>> Best regards,
