[gdal-dev] ERROR 1: No inverse operation
Even Rouault
even.rouault at spatialys.com
Wed Mar 8 03:47:48 PST 2023
Micha,
which CRS is reported and which PROJ version do you use ? It is
presumably one projection method for which PROJ only implements the
forward conversion, that is from geographic to projected coordinates,
but not the reverse way
Even
Le 08/03/2023 à 09:37, Micha Silver a écrit :
> I received some Geotiff files, and gdalinfo shows:
> Corner Coordinates:
> Upper Left ( 205370.241, 418790.721)
> Lower Left ( 205370.241, 415665.721)
> Upper Right ( 206198.866, 418790.721)
> Lower Right ( 206198.866, 415665.721)
> Center ( 205784.553, 417228.221)
> What does that mean?
> gdalinfo --version
> GDAL 3.6.2, released 2023/01/02
> Thanks
> Micha Silver
> Remote Sensing Lab, Sde Boker
> Ben Gurion University
> +972-523-665918
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230308/1c8a9125/attachment.htm>
