[gdal-dev] ERROR 1: No inverse operation
Even Rouault even.rouault at spatialys.com
Wed Mar 8 04:33:09 PST 2023
Ah, the issue here is that the GeoTIFF keys in the .tif partially define
the projection (or possibly the .tif.aux.xml contain this invalid WKT).
But METHOD["unnamed"] means that the projection method is unknown, so it
is logical that GDAL/PROJ can't compute geographic coordinates from
projected coordinates.
The output of "listgeo HiBar_21022022_A1.tif" might be useful to further
diagnose.
You likely need to gdal_translate -a_srs EPSG:2039 to do something
useful with that file, and report to the data producer that the CRS
encoding is broken
Le 08/03/2023 à 13:18, Micha Silver a écrit :
> Hi Even:
> Here's the full gdalinfo, with the reported CRS:
> gdalinfo HiBar_21022022_A1.tif
> Driver: GTiff/GeoTIFF
> Files: HiBar_21022022_A1.tif
>       HiBar_21022022_A1.tif.aux.xml
> Size is 25000, 25000
> Coordinate System is:
> PROJCRS["Israel 1993 / Israeli TM Grid",
>    BASEGEOGCRS["WGS 84",
>        DATUM["World Geodetic System 1984",
>            ELLIPSOID["WGS 84",6378137,298.257223563,
>                LENGTHUNIT["metre",1,
>                    ID["EPSG",9001]]]],
>        PRIMEM["Greenwich",0,
>            ANGLEUNIT["degree",0.0174532925199433,
>                ID["EPSG",9122]]]],
>    CONVERSION["unnamed",
>        METHOD["unnamed"]],
>    CS[Cartesian,2],
>        AXIS["(E)",east,
>            ORDER[1],
>                ID["EPSG",9001]]],
>        AXIS["(N)",north,
>            ORDER[2],
>                ID["EPSG",9001]]]]
> Data axis to CRS axis mapping: 1,2
> Origin = (202245.240786847687559,421915.720555976789910)
> Pixel Size = (0.125000000000000,-0.125000000000000)
> Metadata:
>  AREA_OR_POINT=Area
> Image Structure Metadata:
>  INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (  202245.241,  421915.721)
> Lower Left  (  202245.241,  418790.721)
> Upper Right (  205370.241,  421915.721)
> Lower Right (  205370.241,  418790.721)
> Center      (  203807.741,  420353.221)
> and proj version:
> proj
> Rel. 9.1.1, December 1st, 2022
> (a newly installed debian 12)
> Thanks,
> Micha
> On 08/03/2023 13:47, Even Rouault wrote:
>> Micha,
>> which CRS is reported and which PROJ version do you use ? It is
>> presumably one projection method for which PROJ only implements the
>> forward conversion, that is from geographic to projected coordinates,
>> but not the reverse way
>> Even
>> Le 08/03/2023 à 09:37, Micha Silver a écrit :
>>> I received some Geotiff files, and gdalinfo shows:
>>> Corner Coordinates:
>>> Upper Left  (  205370.241,  418790.721)
>>> Lower Left  (  205370.241,  415665.721)
>>> Upper Right (  206198.866,  418790.721)
>>> Lower Right (  206198.866,  415665.721)
>>> Center      (  205784.553,  417228.221)
>>> What does that mean?
>>> gdalinfo --version
>>> GDAL 3.6.2, released 2023/01/02
>>> Thanks
>>> Micha Silver
>>> Remote Sensing Lab, Sde Boker
>>> Ben Gurion University
>>> +972-523-665918
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://www.spatialys.com
>> My software is free, but my time generally not.
> Micha Silver
> +972-523-665918
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230308/039f3ebd/attachment-0001.htm>
