[gdal-dev] Removal of Python SWIG python generated files from git
Even Rouault even.rouault at spatialys.com
Thu Mar 9 10:13:46 PST 2023
take this email as a mini-RFC regarding the changes in
https://github.com/OSGeo/gdal/pull/7390 which remove the SWIG python
generated files from git master, and thus make the SWIG binary a
requirement to build the Python bindings.
Below, the text of the PR:
This removes a long-time oddity where the SWIG generated .py and .cpp
files were stored in git, which was inconvenient for contributors,
requiring them to have a precise SWIG version and enabling a specific
CMake variable to resync the generated files to the source files, and
causing confusion to occasional contributors who sometimes accidentally
submitted changes to generated files instead of their source files. This
was also different from the Java and CSharp bindings, which didn't have
the generated files in git and required SWIG to be available to generate
them.
Bonus of this move: in the process, due to some of our most up to date
CI targets using SWIG 4.1, it enabled to fix 2 errors in SWIG syntax
that were rejected by SWIG 4.1 (and hidden up to now due to using 4.0.2
as our baseline)
This change shouldn't be a major hurdle for distributors, as most known
binary distributions did regenerate the files anyway.
Note to people updating an existing git checkout: now the
BUILD_JAVA/CSHARP/PYTHON_BINDINGS CMake variables are strictly honored.
They are now initialized to ON only if all build requirements are
available (SWIG and Python for the python bindings), and if set to ON
but a requirement is missing, CMake fails. This might cause issues for
people for example not having the requirements for the Java or CSharp
bindings, but with an existing CMakeCache.txt with them set. Fix: run
"cmake -UBUILD_JAVA_BINDINGS -UBUILD_CHSARP_BINDINGS
-UBUILD_PYTHON_BINDINGS"
Even
http://www.spatialys.com
