[gdal-dev] GDAL - Python Bindings - CURL NETRC_FILE
Even Rouault even.rouault at spatialys.com
Sun Mar 12 08:35:00 PDT 2023
You're right, I looked too fast. I've added a GDAL_HTTP_NETRC_FILE
option in https://github.com/OSGeo/gdal/pull/7435
Le 12/03/2023 à 16:11, Morgan Kerle a écrit :
> HI Even,
> Thanks for your reply. I had assume that GDAL_HTTP_NETRC set the
> option NETRC as in papszOptions which accepts "YES" or "NO" to
> indicate if ~/.netrc file or $NETRC should be searched for
> credentials. If this is the same option as CURLOPT_NETRC
> (https://curl.se/libcurl/c/CURLOPT_NETRC.html), then it does not allow
> the user to specify a location for the .netrc file. In any case, I
> attempted setting the GDAL_HTTP_NETRC via gdal.SetConfigOption(), but
> I am still getting the same curl output (Couldn't find host
> data.lpdaac.earthdatacloud.nasa.gov
> <http://data.lpdaac.earthdatacloud.nasa.gov> in the (nil) file; using
> defaults).
> I assume (nil) file should be showing the file path supplied via
> GDAL_HTTP_NETRC?
> Morgan
> On Sun, 12 Mar 2023 at 10:58, Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Morgan,
>     The right name is GDAL_HTTP_NETRC :
>     https://gdal.org/api/cpl.html#_CPPv412CPLHTTPFetchPKc12CSLConstList
>     Even
>     GDAL_HTTP_NETRC
>     Le 12/03/2023 à 15:49, Morgan Kerle a écrit :
>>     I am trying to use the /vsicurl/ file hander to access a remote
>>     tiff file using basic auth. Is it possible to provide a alternate
>>     location
>>     for a .netrc file via the Python bindings? I have attempted to
>>     use SetConfigOption("CPL_CURL_NETRC_FILE"
>>     "abs/file/path/to/.netrc").
>>     This appears to correctly set the CURL_NETRC_FILE option, as CURL
>>     debugging output shows "Couldn't find host
>>     using defaults". However, it appears the file is not found /
>>     accessible by libcurl.
>>     Any suggestions as to why this may be the case? I have already
>>     confirmed that the file exists and is accessible, and running
>>     CURL with the same parameters in bash works fine.
>>     Regards,
>>     Morgan
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
>     http://www.spatialys.com
>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230312/daa5a1c4/attachment.htm>
