[gdal-dev] Python bindings: enabling exceptions by default?
Even Rouault
even.rouault at spatialys.com
Fri Mar 24 07:23:28 PDT 2023
https://github.com/OSGeo/gdal/pull/7475 has now been merged into master.
The UseExceptions()/DontUseExceptions() methods when invoked from one
module also affect all other gdal, ogr, osr, gnm modules at once (that
is now gdal.UseExceptions() is equivalent to gdal.UseExceptions() +
ogr.UseExceptions() + osr.UseExceptions() + gnm.UseExceptions())
Even
Le 21/03/2023 à 18:21, Even Rouault a écrit :
> Hi,
> Given the feedback received, I've amended the pull request with an
> extra commit to disable exceptions by default, except in autotest/ and
> scripts. And emit a FutureWarning if exceptions have not been
> explicitly enabled or disabled. So this will test the
> exceptions-by-default mode in the GDAL code base without imposing it
> to external code, and warning such external code that behaviour will
> change in the future
> Even
> Le 19/03/2023 à 13:34, Even Rouault a écrit :
>> Hi,
>> I've prepared a pull request that does the above, but this raises a
>> number of questions. See my longish comment at
>> https://github.com/OSGeo/gdal/pull/7475#issuecomment-1475239852.
>> Thoughts appreciated
>> Even
http://www.spatialys.com
