[gdal-dev] Question regarding Shapefile Geo-cordinates
Robert Hewlett
rob.hewy at gmail.com
Tue May 9 05:37:52 PDT 2023
It sounds like the lat and longs are being plotted as Web Mercator meters.
I could be wrong
Is there a .PRJ file?
How are you viewing the data:
QGIS
Open layers
Leaflet
On Tue, May 9, 2023, 04:55 Vijay Kurhade <vijay.kurhade at gmail.com> wrote:
> Hi;
> I have a long pending issue with Shapefile and using proper
> Geo-coordinates for it;
> i need to place it in Pune, India with actual 4 Geo-Coordinates but
> everytime My shapefile gets placed into earth's center mostly Africa.
> What is the solution; How can I ensure the shapefile uses those lat/long 4
> coordinates and is placed on Pune, India in Map rather than somewhere else?
> Thanks in Advance.
> Regards-
> Vijay
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230509/4ed75b48/attachment.htm>
