[gdal-dev] request limit on netcdf server ?
Even Rouault even.rouault at spatialys.com
Wed May 10 08:16:52 PDT 2023
Michael,
analysis and improvements in https://github.com/OSGeo/gdal/pull/7737
Even
Le 10/05/2023 à 09:03, Michael Sumner a écrit :
> I'm having trouble with remote dsn from here:
> https://esgf.nci.org.au/thredds/catalog/esgcet/cmip5/output1/CSIRO-BOM/ACCESS1-3/rcp85/day/ocean/day/r1i1p1/cmip5.output1.CSIRO-BOM.ACCESS1-3.rcp85.day.ocean.day.r1i1p1.v20120413.html#cmip5.output1.CSIRO-BOM.ACCESS1-3.rcp85.day.ocean.day.r1i1p1.v20120413
> The support tells me I have been blocked for requests from my IP that
> exceed 300 in 5min. Apparently, daily you are cleared from the
> blocklist but with experiments today I've had two machines blocked
> (and now manually cleared). Still, it's hard to test :0
> I've stripped down to this dsn, I thought limiting  the driver might
> limit the requests because it won't cascade down the driver
> identification (but I'm not sure if -if adds anymore than the
> "NETCDF:" is already doing). At any rate I need to target a subdataset
> so I need that syntax.
> "vrt://NETCDF:\"/vsicurl/https://esgf.nci.org.au/thredds/fileServer/master/CMIP5/output1/CSIRO-BOM/ACCESS1-3/rcp85/day/ocean/day/r1i1p1/v20120413/tos/tos_day_ACCESS1-3_rcp85_r1i1p1_20560101-20651231.nc\
> <https://esgf.nci.org.au/thredds/fileServer/master/CMIP5/output1/CSIRO-BOM/ACCESS1-3/rcp85/day/ocean/day/r1i1p1/v20120413/tos/tos_day_ACCESS1-3_rcp85_r1i1p1_20560101-20651231.nc\>":tos?bands=1&if=NETCDF"
> It takes quite a while to read one band, but the warper and RasterIO
> result is good.  I think the machine is now blocked again, I wasn't
> able to also run gdalinfo after warper and straight read.
> I'm just doing standalone from-scratch opens, not with a persistent
> dataset - I assume that would reduce the request load, which I'll try
> in python when I have access again.
> Questions:
> 1. Are there other things I can pursue to reduce my request load on
> the server?
> 2. Can this actually be faster?  RasterIO for one band 360x300 was
> minutes.  (I appreciate this might be better suited to mdim, but that
> seems similarly problematic in terms of requests and performance).
> I've tried the config options   GDAL_NETCDF_VERIFY_DIMS / STRICT and
> GDAL_NETCDF_IGNORE_XY_AXIS_NAME_CHECK=/YES and that does seem to have
> helped the warper request but RasterIO was still slow.
> This was on GDAL 3.8.0dev-414270a94b-dirty, released 2023/05/09 (debug
> build)
> I see this repeated warning
> Warning 1: dimension #2 (i) is not a Longitude/X dimension.
> Warning 1: dimension #1 (j) is not a Latitude/Y dimension.
> Warning 1: dimension #1 (i) is not a Longitude/X dimension.
> Warning 1: dimension #0 (j) is not a Latitude/Y dimension.
> Thank you
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230510/93b15778/attachment-0001.htm>
