[gdal-dev] Extracting Jpeg2000 image from nitf file
Even Rouault
even.rouault at spatialys.com
Fri May 26 03:09:50 PDT 2023
if you open such an image with debug traces (CPL_DEBUG=ON), you'll see
something like
GDAL: GDALOpen(/vsisubfile/907_565,byte.ntf, this=....) succeeds as
JP2OpenJPEG
which means that the JPEG2000 file starts at byte 907 with a length of
565 bytes.
Programatically from C/C++ , you could use the GDALGetOpenDatasets()
methods after having opening the NITF file, and look for /vsisubfile/ files
Even
Le 26/05/2023 à 08:57, Tobby Moalem a écrit :
> Hi,
> For my understanding the nitf file is used as container, where
> compressed jpeg2000 can be saved inside the nitf file.
> I wonder if there is a way to use gdal to extract the jpeg2000 part
> and save it separately (with extension of .j2c or other jpeg2000
> extensions) ?
> Thanks in advance,
> Tobby
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
