[gdal-dev] configuration option GDAL_RASTERIO_RESAMPLING
Daniel Baston
dbaston at gmail.com
Sat May 27 17:33:24 PDT 2023
Hi Mike,
The content on the page you linked is for the most part a simple transfer
of what was available on the wiki, plus a few options that were previously
defined on driver or other pages. It is not complete.
There are also about 500 configuration options that are used in the code
via CPLGetConfigOption that do not appear in the documentation,
GDAL_RASTERIO_RESAMPLING being one of them. Some of these are clearly not
intended to be part of the GDAL interface, but there's still quite a bit
that can be added to the documentation. I can create an issue and post the
script I used to scan for these if others are interested in filling some of
the gaps.
Dan
On Sat, May 27, 2023 at 8:18 PM Michael Sumner <mdsumner at gmail.com> wrote:
> Hi, I'm very happy to see the refactor of documentation for configuration
> and environment options, primarily by Dan Baston in recent weeks - thanks!
> https://gdal.org/user/configoptions.html
> Does the GDAL_RASTERIO_RESAMPLING option belong in this list? I'm
> exploring its use versus setting resampling with the API, and I gather also
> that there is not an analogous config option for the warper.
> Thank you, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230527/b7cbf665/attachment-0001.htm>
