[gdal-dev] GDAL installation write permissions
sibylle.stoeckli at gmx.ch sibylle.stoeckli at gmx.ch
Tue Aug 6 01:48:35 PDT 2024
Dear community
I tried to install GDAL.
(base) C:\Users\Sibylle Stöckli>conda install -c conda-forge gdal
However I got the following error
Downloading and Extracting Packages:
Preparing transaction: done
Verifying transaction: failed
EnvironmentNotWritableError: The current user does not have write
permissions to the target environment.
  environment location: C:\ProgramData\miniconda3
Kind regards
Sibylle
Full code
Channels:
- conda-forge
- defaults
Platform: win-64
Collecting package metadata (repodata.json): done
Solving environment: done
## Package Plan ##
  added / updated specs:
    - gdal
The following NEW packages will be INSTALLED:
  blosc              conda-forge/win-64::blosc-1.21.6-h85f69ea_0
  freexl             conda-forge/win-64::freexl-2.0.0-h8276f4a_0
  gdal               conda-forge/win-64::gdal-3.9.1-py312h16ac12d_11
  geos               conda-forge/win-64::geos-3.12.2-h5a68840_1
  geotiff            conda-forge/win-64::geotiff-1.7.3-h232476a_2
  intel-openmp       conda-forge/win-64::intel-openmp-2024.2.0-h57928b3_980
  krb5               conda-forge/win-64::krb5-1.21.3-hdf4eb48_0
  lerc               conda-forge/win-64::lerc-4.0.0-h63175ca_0
  libblas            conda-forge/win-64::libblas-3.9.0-23_win64_mkl
  libcblas           conda-forge/win-64::libcblas-3.9.0-23_win64_mkl
  libdeflate         conda-forge/win-64::libdeflate-1.21-h2466b09_0
  libexpat           conda-forge/win-64::libexpat-2.6.2-h63175ca_0
  libgdal-core       conda-forge/win-64::libgdal-core-3.9.1-h6b59ad6_11
  libhwloc
conda-forge/win-64::libhwloc-2.11.1-default_h8125262_1000
  libjpeg-turbo      conda-forge/win-64::libjpeg-turbo-3.0.0-hcfcfb64_1
  libkml             conda-forge/win-64::libkml-1.3.0-h538826c_1020
  liblapack          conda-forge/win-64::liblapack-3.9.0-23_win64_mkl
  libpng             conda-forge/win-64::libpng-1.6.43-h19919ed_0
  librttopo          conda-forge/win-64::librttopo-1.1.0-h6c42fcb_16
  libspatialite      conda-forge/win-64::libspatialite-5.1.0-hab0cb6d_9
  libsqlite          conda-forge/win-64::libsqlite-3.46.0-h2466b09_0
  libtiff            conda-forge/win-64::libtiff-4.6.0-hb151862_4
  libwebp-base       conda-forge/win-64::libwebp-base-1.4.0-hcfcfb64_0
  libzlib            conda-forge/win-64::libzlib-1.3.1-h2466b09_1
  lzo                conda-forge/win-64::lzo-2.10-hcfcfb64_1001
  minizip            conda-forge/win-64::minizip-4.0.6-hb638d1e_0
  mkl                conda-forge/win-64::mkl-2024.1.0-h66d3029_694
  numpy              conda-forge/win-64::numpy-2.0.1-py312h49bc9c5_0
  proj               conda-forge/win-64::proj-9.4.1-hd9569ee_1
  pthreads-win32     conda-forge/win-64::pthreads-win32-2.9.1-hfa6e2cd_3
  python_abi         conda-forge/win-64::python_abi-3.12-4_cp312
  snappy             conda-forge/win-64::snappy-1.2.1-h23299a8_0
  tbb                conda-forge/win-64::tbb-2021.12.0-hc790b64_3
  ucrt               conda-forge/win-64::ucrt-10.0.22621.0-h57928b3_0
  uriparser          conda-forge/win-64::uriparser-0.9.8-h5a68840_0
  vc14_runtime
conda-forge/win-64::vc14_runtime-14.40.33810-ha82c5b3_20
  xerces-c           conda-forge/win-64::xerces-c-3.2.5-he0c23c2_1
The following packages will be UPDATED:
  ca-certificates    pkgs/main::ca-certificates-2024.3.11-~ -->
conda-forge::ca-certificates-2024.7.4-h56e8100_0
  certifi            pkgs/main/win-64::certifi-2024.6.2-py~ -->
conda-forge/noarch::certifi-2024.7.4-pyhd8ed1ab_0
  conda              pkgs/main::conda-24.5.0-py312haa95532~ -->
conda-forge::conda-24.7.1-py312h2e8e312_0
  fmt                       pkgs/main::fmt-9.1.0-h6d14046_1 -->
conda-forge::fmt-10.2.1-h181d51b_0
  libarchive         pkgs/main::libarchive-3.6.2-hb62f4d4_3 -->
conda-forge::libarchive-3.7.4-haf234dc_0
  libcurl               pkgs/main::libcurl-8.7.1-h86230a5_0 -->
conda-forge::libcurl-8.9.1-h18fefc2_0
  libiconv              pkgs/main::libiconv-1.16-h2bbff1b_3 -->
conda-forge::libiconv-1.17-hcfcfb64_2
  libsolv              pkgs/main::libsolv-0.7.24-h23ce68f_1 -->
conda-forge::libsolv-0.7.30-hbb528cf_0
  libxml2              pkgs/main::libxml2-2.10.4-h0ad7f3c_2 -->
conda-forge::libxml2-2.12.7-h0f24e4e_4
  openssl              pkgs/main::openssl-3.0.14-h827c3e9_0 -->
conda-forge::openssl-3.3.1-h2466b09_2
  pcre2                   pkgs/main::pcre2-10.42-h0ff8eda_1 -->
conda-forge::pcre2-10.44-h3d7b363_0
  vs2015_runtime     pkgs/main::vs2015_runtime-14.29.30133~ -->
conda-forge::vs2015_runtime-14.40.33810-h3bf8584_20
  zlib                    pkgs/main::zlib-1.2.13-h8cc25b3_1 -->
conda-forge::zlib-1.3.1-h2466b09_1
  zstandard          pkgs/main::zstandard-0.22.0-py312h346~ -->
conda-forge::zstandard-0.23.0-py312h7606c53_0
  zstd                     pkgs/main::zstd-1.5.5-hd43e919_2 -->
conda-forge::zstd-1.5.6-h0ea2cb4_0
The following packages will be SUPERSEDED by a higher-priority channel:
  libmamba             pkgs/main::libmamba-1.5.8-h99b1521_2 -->
conda-forge::libmamba-1.5.8-h3f09ed1_0
  libmambapy         pkgs/main::libmambapy-1.5.8-py312h77c~ -->
conda-forge::libmambapy-1.5.8-py312h66cf91f_0
  libssh2              pkgs/main::libssh2-1.11.0-h291bd65_0 -->
conda-forge::libssh2-1.11.0-h7dfc565_0
  pybind11-abi         pkgs/main::pybind11-abi-5-hd3eb1b0_0 -->
conda-forge::pybind11-abi-4-hd8ed1ab_3
  python                pkgs/main::python-3.12.4-h14ffc60_1 -->
conda-forge::python-3.12.4-h889d299_0_cpython
  tk                        pkgs/main::tk-8.6.14-h0416ee5_0 -->
conda-forge::tk-8.6.13-h5226925_1
Proceed ([y]/n)? y
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240806/2b082140/attachment.htm>
