[gdal-dev] GDAL 3.9.2 release candidate available
Even Rouault even.rouault at spatialys.com
Mon Aug 12 01:01:48 PDT 2024
Scott,
Le 12/08/2024 à 02:19, Scott via gdal-dev a écrit :
> Looking at the news file, specifically about gdallocationinfo:
> gdallocationinfo: avoid extra newline character in -valonly mode if
> coordinate is outside raster extent (3.9.0 regression)
> Having that new-line character is imperative.
The fix does what you describe (cf tests added in
https://github.com/OSGeo/gdal/commit/c308cf3d9a59c9cdf2916585de273cdf54ab9bb4).
The issue in 3.9.0 and 3.9.1 was that there were 2 newlines instead of a
single one.
| Ideally, it would be real nice to have an option that returns the
coord and value on a single line.
That's the -E echo mode. Except I now realize it doesn't work as
expected in -geoloc/-wgs84 mode, where it reports the pixel, line value,
whereas the documentation and example suggests that it should be the
(non-transformed) input coordinates. I've queued a fix for that in
https://github.com/OSGeo/gdal/pull/10586 . It will probably be in 3.9.3,
unless there's a RC2
Even
http://www.spatialys.com
