[gdal-dev] Trouble with gdaldem -exact_color_entry
Even Rouault
even.rouault at spatialys.com
Wed Aug 14 03:45:18 PDT 2024
There was indeed an issue with the -exact_color_entry mode. Will be
fixed per https://github.com/OSGeo/gdal/pull/10596
As your input band is integer, you can safely use -nearest_color_entry
or the default linear interpretation mode (potentially adding an entry
"12 0 0 0 0" in case you want to map values >= 12 to transparent)
Even
Le 14/08/2024 à 08:28, Daniel Mannarino via gdal-dev a écrit :
> Hi all!
> I'm having trouble getting gdaldem to work the way I believe it's
> supposed to. In particular I have given it a single-band uint8 GeoTIFF
> and tried to map the values to RGB bands via a colormap using exact
> matching, but the resulting GeoTIFF is invariably all zeroes (as if
> there were no matches). Using -nearest_color_entry or not specifying
> -exact_color_entry yields the expected results, but I only want exact
> matches. I have tried specifying values to match as both floats (0.0,
> 1.0, etc.) and ints (0, 1, etc.). Adding an alpha channel makes no
> difference in this sense. Am I doing something wrong, or is there an
> issue with gdaldem? Here are the commands I used, and a link to the
> files in question:
> gdaldem color-relief -co COMPRESS=DEFLATE -co TILED=YES -co
> BLOCKXSIZE=256 -co BLOCKYSIZE=256 -co SPARSE_OK=TRUE -co
> INTERLEAVE=BAND -exact_color_entry -alpha foo.tif colormap.txt
> exact_foo_with_alpha.tif
> INTERLEAVE=BAND -nearest_color_entry -alpha foo.tif colormap.txt
> nearest_foo_with_alpha.tif
> INTERLEAVE=BAND -alpha foo.tif colormap.txt gradient_foo_with_alpha.tif
> https://drive.google.com/drive/folders/17q3zQAcOqPTo4f8-swWEgrpQ9sfufasR?usp=share_link
> These commands were performed with GDAL 3.9.1 installed on MacOS/ARM
> via Homebrew, though the problem also occurs in our AMD64 AWS
> instances running Linux and GDAL 3.8.4 with the official Docker images
> as a base.
> Thanks for any help!
> Daniel Mannarino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
