[gdal-dev] Question about gdal-dev archive - searching for information on reading HDF, SAR_CEOS metadata
Even Rouault
even.rouault at spatialys.com
Thu Aug 15 12:46:06 PDT 2024
Shawn,
can you be more specific about the issue? (ideally with a link to test
datasets, and outputs of gdalinfo with older and newer versions)
Even
Le 15/08/2024 à 21:15, Fox, Shawn D (US) via gdal-dev a écrit :
> Is there any way to search the archive? So far, I have only found a
> way to show the threads for a particular month/year, but I don’t see a
> way to do a keyword search. My team has recently tried to upgrade
> from a very old version 1.10.0 to 3.4.2 and we can no longer
> successfully read metadata from HDF4, HDF5, and CEOS_SAR files in the
> same way that we could do so in the past.
> Has anyone on the list had a similar experience when upgrading? The
> driver and plugin pages for these data types has already been reviewed
> and we could not find any information to explain what change I need to
> make to read metadata again. I can provide more specifics but wanted
> to know if anyone was willing to collaborate on that topic and share
> information.
> Thanks,
> Shawn Fox
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240815/8bc65714/attachment.htm>
