[gdal-dev] FileGDBs and FIDs of -21121
Seth G
sethg at geographika.co.uk
Tue Aug 27 13:31:13 PDT 2024
Thanks Even for the details.
Sorry, the FID is correctly populated (with an autogenerated FID values starting from 1). However the unique ID of the feature is exported in a separate attribute field, and it is in this field that all values are present in the FileGDB except for the record with -21121:
FID UniqueId
1 -21119
2 -21120
3 NULL (this should be -21121)
Looks like this could be a MapServer rather than GDAL issue so I'll debug further,
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Tue, Aug 27, 2024, at 10:03 PM, Even Rouault wrote:
> Seth,
> I'm not totally sure to understand the exact scenario. -21121 is a
> special value for OGRField, which is a distinct concept that the Feature
> ID, and normally it shouldn't prevent setting Integer64 fields to the
> value as this canary is set in 2 fields of OGRField.
> from osgeo import ogr
> layer_defn = ogr.FeatureDefn("test")
> layer_defn.AddField(ogr.FieldDefn("i64", ogr.OFTInteger64))
> layer_defn.AddFieldDefn(ogr.FieldDefn("i64", ogr.OFTInteger64))
> f = ogr.Feature(layer_defn)
> f["i64"] = -21121
> f.DumpReadable()
> OGRFeature(test):-1
> i64 (Integer64) = -21121
> But what is sure is that the OpenFileGDB driver will error out if you
> pass to CreateFeature() a feature with a FID < -1, = 0 or > INT32_MAX,
> since the FileGDB format only supports FID in the range [1, INT32_MAX],
> and -1 is the OGRNullFID special constant to indicate that you let the
> driver automatically assign a FID.
> With GeoJSON, you would likely have an issue with features of FID = -1
> which would get assign a FID by the driver. Basically most formats will
> struggle with negative or null FIDs
> What is perhaps missing in MapServer is a FORMATOPTION "SET_FID=FALSE"
> for drivers such as FileGDB (or "FID_VALID_MIN" and "FIX_VALID_MAX" ?)
> to limit the scope of calls to OGR_F_SetFID() by MapServer.
> Even
> Le 27/08/2024 à 21:32, Seth G via gdal-dev a écrit :
>> Hi all,
>> I'm using a GDAL within MapServer to export features as a FileGDB. Using the following OUTPUTFORMAT:
>> OUTPUTFORMAT
>> NAME "FileGDB"
>> DRIVER "OGR/OpenFileGDB"
>> MIMETYPE "application/x-ogcfilegdb"
>> FORMATOPTION "STORAGE=filesystem"
>> FORMATOPTION "FORM=zip"
>> FORMATOPTION "FILENAME=result.gdb.zip"
>> FORMATOPTION "LCO:FID=FID"
>> END
>> I ran into an issue where a single feature Id is being set to NULL. After checking various database queries and configs it looks like the issue is when a feature id is -21121 and data exported to a FileGDB. When using GeoJSON the Id is returned correctly.
>> I searched in the GDAL codebase and found that this is a "magic" number: https://github.com/search?q=repo%3AOSGeo%2Fgdal%20-21121&type=code
>> #define OGRUnsetMarker -21121
>> Is there any way round this other than using different Ids?
>> Thanks,
>> Seth
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
