[gdal-dev] WMTS gdal_translate vs RasterIO
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Fri Aug 30 00:23:18 PDT 2024
Capture and show the http request that your code generates and sends to the WMTS server. Does it work if you send the same request with curl or with a browser? Or does the error come before the GetTile request is generated?
-Jukka Rahkonen-
Lähettäjä: Michał Kowalczuk <michkowalczuk at gmail.com>
Lähetetty: perjantai 30. elokuuta 2024 9.59
Vastaanottaja: Robert Coup <robert.coup at koordinates.com>
Kopio: gdal-dev at lists.osgeo.org; Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: [gdal-dev] WMTS gdal_translate vs RasterIO
Sorry for incorrect sample commands in the last message.
I fixed it. The problem stays the same, because the problem was in email not in my tested code.
gdal_translate -srcwin 0 0 1073741760 1553779 -outsize 691 1 "WMTS:https://basemap.nationalmap.gov/arcgis/rest/services/USGSHydroCached/MapServer/WMTS/1.0.0/WMTSCapabilities.xml,layer=USGSHydroCached,tilematrixset=default028mm" tile.png
GDALDatasetRasterIO(
handle_to_wmts_subdataset,
eRWFlag=GF_Read,
nXOff=0,
nYOff=0,
nXSize=1073741760,
nYSize=1553779,
pBuffer - buffer for data,
nBufXSize=691,
nBufYSize=1,
eBufType=GDT_Byte,
nBandCount=4,
panBandMap=[bIndex ,gIndex, rIndex, aIndex],
nPixelSpace=4,
nLineSpace=0,
nBandSpace=1)
Can anyone help me to understand why gdal_translate works and generates output file, where GDALRasterIO raises error:
Requested (0,0) of size 1073741760x1553779 on raster of 1073741756x1347126255?
czw., 29 sie 2024 o 12:22 Michał Kowalczuk <michkowalczuk at gmail.com<mailto:michkowalczuk at gmail.com>> napisał(a):
I see. I will double check commands, fix and return to this.
W dniu czw., 29.08.2024 o 12:20 Robert Coup <robert.coup at koordinates.com<mailto:robert.coup at koordinates.com>> napisał(a):
Hi Michał,
In addition to Jukka's key point:
  nBufXSize=1,
  nBufYSize=691,
appears to be backwards wrt:
  -outsize 691 1
Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240830/fb0f733b/attachment-0001.htm>
