[gdal-dev] AutoCreateWarpedVRT changes Int16 raster to Int32
Even Rouault
even.rouault at spatialys.com
Sat Aug 31 15:58:37 PDT 2024
What is the gdalinfo output on dem.tif ?
> Is this a bug? It appears that the data type change might be
> influenced by the nodata value.
Yes, there is some logic to take the "union" of the largest data types
involved in the warping (but it should probably ignore nodata values
that are outside of the validity range of the input data type. I didn't
check what it does currently)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240901/17d45afc/attachment.htm>
