[gdal-dev] NetCDF: how to read coordinates from "lon" and "lat" variables?
Michael Sumner
mdsumner at gmail.com
Tue Dec 3 03:01:50 PST 2024
Try
gdalinfo NETCDF:"out.input.nc":NO2
If you see those lon and lat subdatasets listed under "geolocation" then
you can use gdalwarp to create a georeferenced dataset, automatically with
gdalwarp sds.in out.tif or by specifying a grid with some of
-tr,-te,-t_srs,-ts.
If they don't appear they can can be arranged via VRT.
HTH
On Tue, 3 Dec 2024, 21:52 andy via gdal-dev, <gdal-dev at lists.osgeo.org>
wrote:
> Hi,
> I have a NetCDF file that I cannot share here.
> Using gdalinfo I have the below output.
> Is there any way to tell gdal to read coordinates from the “lon” and “lat”
> variables/subdatasets, and thus have the coordinates of the vertices not in
> pixels?
> Thank you very much
> Driver: netCDF/Network Common Data Format
> Files: none associated
> Size is 512, 512
> Subdatasets:
> SUBDATASET_1_NAME=NETCDF:"out.input.nc":NO2
> SUBDATASET_1_DESC=[25x1x229x174] NO2 (32-bit floating-point)
> SUBDATASET_2_NAME=NETCDF:"out.input.nc":O3
> SUBDATASET_2_DESC=[25x1x229x174] O3 (32-bit floating-point)
> SUBDATASET_3_NAME=NETCDF:"out.input.nc":PM10
> SUBDATASET_3_DESC=[25x1x229x174] PM10 (32-bit floating-point)
> SUBDATASET_4_NAME=NETCDF:"out.input.nc":PM25
> SUBDATASET_4_DESC=[25x1x229x174] PM25 (32-bit floating-point)
> SUBDATASET_5_NAME=NETCDF:"out.input.nc":Times
> SUBDATASET_5_DESC=[25x19] Times (8-bit character)
> SUBDATASET_6_NAME=NETCDF:"out.input.nc":lat
> SUBDATASET_6_DESC=[229x174] lat (64-bit floating-point)
> SUBDATASET_7_NAME=NETCDF:"out.input.nc":lon
> SUBDATASET_7_DESC=[229x174] lon (64-bit floating-point)
> SUBDATASET_8_NAME=NETCDF:"out.input.nc":pDUST
> SUBDATASET_8_DESC=[25x1x229x174] pDUST (32-bit floating-point)
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 512.0)
> Upper Right ( 512.0, 0.0)
> Lower Right ( 512.0, 512.0)
> Center ( 256.0, 256.0)
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
> in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241203/fb6dd606/attachment.htm>
