[gdal-dev] NetCDF: how to read coordinates from "lon" and "lat" variables?
andy
aborruso at gmail.com
Tue Dec 3 05:51:23 PST 2024
Hi Michael,
It seems to work.
Is there no way not to hard-code the GeoTransform, SrcRect, etc.
parameters?
Thank you
<VRTDataset rasterXSize="174" rasterYSize="229">
<SRS>EPSG:4326</SRS>
<GeoTransform>4.36, 0.0894, 0.0, 48.88, 0.0, -0.0597</GeoTransform>
<VRTRasterBand dataType="Float32" band="1">
<Metadata>
<MDI key="long_name">NO2 Concentration</MDI>
<MDI key="units">ppb vol</MDI>
</Metadata>
<ComplexSource>
<SourceFilename relativeToVRT="1">NETCDF:"out.input.nc
":NO2</SourceFilename>
<SourceBand>1</SourceBand>
<SourceProperties RasterXSize="174" RasterYSize="229"
DataType="Float32" BlockXSize="174" BlockYSize="1" />
<SrcRect xOff="0" yOff="0" xSize="174" ySize="229" />
<DstRect xOff="0" yOff="0" xSize="174" ySize="229" />
</ComplexSource>
</VRTRasterBand>
</VRTDataset>
On Tue, 3 Dec 2024 at 12:02, Michael Sumner <mdsumner at gmail.com> wrote:
> Try
> gdalinfo NETCDF:"out.input.nc":NO2
> If you see those lon and lat subdatasets listed under "geolocation" then
> you can use gdalwarp to create a georeferenced dataset, automatically with
> gdalwarp sds.in out.tif or by specifying a grid with some of
> -tr,-te,-t_srs,-ts.
> If they don't appear they can can be arranged via VRT.
> HTH
> On Tue, 3 Dec 2024, 21:52 andy via gdal-dev, <gdal-dev at lists.osgeo.org>
> wrote:
>> Hi,
>> I have a NetCDF file that I cannot share here.
>> Using gdalinfo I have the below output.
>> Is there any way to tell gdal to read coordinates from the “lon” and
>> “lat” variables/subdatasets, and thus have the coordinates of the vertices
>> not in pixels?
>> Thank you very much
>> Driver: netCDF/Network Common Data Format
>> Files: none associated
>> Size is 512, 512
>> Subdatasets:
>> SUBDATASET_1_NAME=NETCDF:"out.input.nc":NO2
>> SUBDATASET_1_DESC=[25x1x229x174] NO2 (32-bit floating-point)
>> SUBDATASET_2_NAME=NETCDF:"out.input.nc":O3
>> SUBDATASET_2_DESC=[25x1x229x174] O3 (32-bit floating-point)
>> SUBDATASET_3_NAME=NETCDF:"out.input.nc":PM10
>> SUBDATASET_3_DESC=[25x1x229x174] PM10 (32-bit floating-point)
>> SUBDATASET_4_NAME=NETCDF:"out.input.nc":PM25
>> SUBDATASET_4_DESC=[25x1x229x174] PM25 (32-bit floating-point)
>> SUBDATASET_5_NAME=NETCDF:"out.input.nc":Times
>> SUBDATASET_5_DESC=[25x19] Times (8-bit character)
>> SUBDATASET_6_NAME=NETCDF:"out.input.nc":lat
>> SUBDATASET_6_DESC=[229x174] lat (64-bit floating-point)
>> SUBDATASET_7_NAME=NETCDF:"out.input.nc":lon
>> SUBDATASET_7_DESC=[229x174] lon (64-bit floating-point)
>> SUBDATASET_8_NAME=NETCDF:"out.input.nc":pDUST
>> SUBDATASET_8_DESC=[25x1x229x174] pDUST (32-bit floating-point)
>> Corner Coordinates:
>> Upper Left ( 0.0, 0.0)
>> Lower Left ( 0.0, 512.0)
>> Upper Right ( 512.0, 0.0)
>> Lower Right ( 512.0, 512.0)
>> Center ( 256.0, 256.0)
>> ___________________
>> Andrea Borruso
>> website: https://medium.com/tantotanto
>> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
>> ___________________
>> "cercare e saper riconoscere chi e cosa,
>> in mezzo all’inferno, non è inferno,
>> e farlo durare, e dargli spazio"
>> Italo Calvino
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
___________________
Andrea Borruso
___________________
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241203/e575284e/attachment-0001.htm>
