[gdal-dev] WMTS generating GET URL problem
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Fri Dec 13 05:52:21 PST 2024
The idea behind all standardization work is not that every single client must be made to deal with servers which break the standard. Contact the server provided and ask them to fix their configuration. There seems to be a contact address in GetCapabilities <ows:ElectronicMailAddress>irisline at paradigm.brussels</ows:ElectronicMailAddress<mailto:irisline at paradigm.brussels%3c/ows:ElectronicMailAddress>>
-Jukka Rahkonen-
Lähettäjä: Michał Kowalczuk <michkowalczuk at gmail.com>
Lähetetty: perjantai 13. joulukuuta 2024 15.38
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] WMTS generating GET URL problem
so maybe this little fix for this should be madę in gdal.
if style isEmpty:
    style="default"
W dniu pt., 13 gru 2024 o 14:32 Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> napisał(a):
By the standard Web Map Tile Service - Open Geospatial Consortium<https://www.ogc.org/publications/standard/wmts/> "style" seems to be mandatory in the layer data "One or more (mandatory)".
And within "style", the identifier is mandatory "An unambiguous reference to this style, identifying a specific version when needed, normally used by software"; multiplicity: One (mandatory).
I would say that this is a server side misconfiguration. Each style must have an identifier, even the default style. But the server does still understand the style named as "default":
https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/Ortho/default/EPSG:4326/EPSG:4326:7/27/129?format=image/jpeg
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta Michal Kowalczuk via gdal-dev
Lähetetty: perjantai 13. joulukuuta 2024 14.43
Vastaanottaja: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Sorry for the mistake in the last email. Instead of pasting gfdalinfo command i should paste this:
gdal_translate -srcwin 0 0 12235811 6137602 -outsize 512 512 "WMTS:https://geoservices-urbis.irisnet.be/geoserver/gwc/service/wmts?SERVICE=WMTS&REQUEST=GetCapabilities&VERSION=1.0.0,layer=Ortho,tilematrixset=EPSG:4326" tile.png --debug on --config GDAL_ENABLE_WMS_CACHE NO
pt., 13 gru 2024 o 13:15 Michał Kowalczuk <michkowalczuk at gmail.com<mailto:michkowalczuk at gmail.com>> napisał(a):
Consider the following WMTS server:
One of the subdataset path generated by GDAL is
When I try to download a map I notice URL issue/error.
gdalinfo "WMTS:https://geoservices-urbis.irisnet.be/geoserver/gwc/service/wmts?SERVICE=WMTS&REQUEST=GetCapabilities&VERSION=1.0.0,layer=Ortho,tilematrixset=EPSG:4326" tile.png --debug on --config GDAL_ENABLE_WMS_CACHE NO
from debug:
HTTP: Requesting [1/4] https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/Ortho//EPSG:4326/EPSG:4326:7/27/129?format=image/jpeg
look at the double slash (//) chars in the above URL
When you go to service Capabilities you can find the following resource URL:
 <ResourceURL format="image/jpeg" resourceType="tile" template="https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/urbisNL/{style}/{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}?format=image/jpeg"/>
but in the layer definition Style tag is empty:
<Style isDefault="true">
<ows:Identifier/>
</Style>
This is probably the reason that GDAL make path using an empty string and this generate double slash chars.
If you remove redundant slash the server responses and returns a tile, the example:
https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/Ortho/EPSG:4326/EPSG:4326:14/3567/16784?format=image/jpeg
And the question is: is this service or GDAL bug?  :-)
Wouldn't it be a good idea for GDAL to check the URL path for correctness before sending the request?
Regards,
Michał
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241213/800c10c6/attachment-0001.htm>
