[gdal-dev] Which options to use to avoid the symbol clash between GDAL and external libgeotiff and external TIFF libraries
Even Rouault
even.rouault at spatialys.com
Tue Dec 17 05:49:17 PST 2024
You don't need to set any explicit option for symbol renaming. This is
done automatically as soon as internal libraries are used
Le 17/12/2024 à 10:57, Parveen Sharma via gdal-dev a écrit :
> Hello
> I am trying to build GDAL 3.9.3 using CMAKE and want to avoid the
> *symbol clash between GDAL and external libgeotiff and external TIFF
> libraries.*
> I have enabled the GDAL internal TIFF and GEOTIFF with below CMAKE
> options*
> <arg value="-DGDAL_USE_LIBTIFF_INTERNAL=ON"/>
> <arg value="-DGDAL_USE_GEOTIFF_INTERNAL=ON"/>
> *But i am confused which of the below is valid option to rename the
> internal symbols so that they don't clash with the external libraries
> symbols.
> All of the below 4 are present in GDAL 3.9.3 code base and I am unable
> to figure out which one to use
> <arg value="-DRENAME_INTERNAL_LIBTIFF_SYMBOLS=ON"/>
> <arg value="-DRENAME_INTERNAL_LIBGEOTIFF_SYMBOLS=ON"/>
> <arg value="-DRENAME_INTERNAL_GEOTIFF_SYMBOLS=ON"/>
> <arg value="-DRENAME_INTERNAL_TIFF_SYMBOLS=ON"/>
> Can anyone please suggest?
> Best regards,
> Parveen
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241217/686fb5e2/attachment-0001.htm>
