[gdal-dev] Hi: GDAL CONFIG
Michał Kowalczuk
michkowalczuk at gmail.com
Wed Dec 18 02:05:58 PST 2024
Thank you Jukka, it helps in command line.
Now I need to investigate why the same but using C API fails.
The issue scenario is:
1. I set *GDAL_HTTP_USERPWD* using *CPLSetConfigOption*
2. I connect to the service as dataset (*GDALOpen*)
3. I get the first subdataset (*GDALOpen*) and download data using
*GdalRasterIO*
4. I connect to the second subdataset and when I got handle to it,
*GDAL_HTTP_USERPWD
env variable is cleared!*
5. So GdalRasterIO fails because of lack the credentials...
Strange... 🤷
wt., 17 gru 2024 o 20:07 Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
napisał(a):
> Hi,
> Have you tried
> *set GDAL_HTTP_USERPWD=user:pass*
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Michal
> Kowalczuk via gdal-dev
> *Lähetetty:* tiistai 17. joulukuuta 2024 19.49
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] GDAL CONFIG
> Dear GDAL colleagues,
> do you have any idea why the first method fails:
> *set GDAL_HTTP_USERPWD="user:pass"*
> *gdal_translate -srcwin 0 0 1073696614, 1073741824 -outsize 512 512
> "WMS:https://maps.lantmateriet.se/topowebb/wms/v1?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=topowebbkartan&SRS=epsg:3006&BBOX=-1.19998e+06,4.69998e+06,2.59988e+06,8.5e+06
> <https://maps.lantmateriet.se/topowebb/wms/v1?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=topowebbkartan&SRS=epsg:3006&BBOX=-1.19998e+06,4.69998e+06,2.59988e+06,8.5e+06>"
> tile1.png*
> but the second works?
> tile1.png --config GDAL_HTTP_USERPWD "user:pass"*
> (windows, GDAL 3.9.2, anaconda prompt)
> Regards,
> Michał Kowalczuk
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241218/f9a8f8f8/attachment.htm>
