[gdal-dev] Modify DST_SRS in Python RasterizeLayer
Even Rouault even.rouault at spatialys.com
Wed Dec 18 07:52:58 PST 2024
William,
Le 18/12/2024 à 13:05, Starms, William (MU-Student) via gdal-dev a écrit :
> Howdy! I’m trying to rasterize a shape that is in absolute pixel/line
> coordinates, but it gets burned wrong if the destination dataset has
> an srs due to coordinate conversion. There aren’t any docs for that
> specific function
> (https://gdal.org/en/stable/api/python/utilities.html#osgeo.gdal.RasterizeLayer)
> so I dug into the C++/CLI options
> (https://gdal.org/en/latest/api/gdal_alg.html#_CPPv432GDALCreateGenImgProjTransformer212GDALDatasetH12GDALDatasetHPPc)
> but couldn’t get them working.
You can't directly pass transformer options that apply to
GDALCreateGenImgProjTransformer() though GDALRasterizeLayer(). The
former will use the later and compose transformer options with the logic
at https://github.com/OSGeo/gdal/blob/master/alg/gdalrasterize.cpp#L1659
There were 2 issues in your code:
- you didn't attach the SRS to the vector layer
- the bounds of your raster minx,miny=(30,30)-maxx,maxy=(40,40) don't
intersect the envelope of your geometry minx,miny=(3,5)-maxx,maxy=(24,29)
Fixed version below, with a modified geometry within the raster extent
and with an option to use a geotransform or GCPs:
from osgeo import gdal, ogr, osr
gdal.UseExceptions()
def make_ogr_feature(spatial_ref, shape):
     rast_ogr_ds = ogr.GetDriverByName('Memory').CreateDataSource('wrk')
     rast_mem_lyr = rast_ogr_ds.CreateLayer('poly', srs=spatial_ref)
     feat = ogr.Feature(rast_mem_lyr.GetLayerDefn())
     feat.SetGeometryDirectly(ogr.Geometry(wkt=shape))
     rast_mem_lyr.CreateFeature(feat)
     return rast_mem_lyr, rast_ogr_ds
driver = gdal.GetDriverByName('GTiff')
ds = driver.Create('set.tif', xsize=100, ysize=100, bands=3,
eType=gdal.GDT_Byte)
srs = osr.SpatialReference()
srs.ImportFromEPSG(4326)
srs.SetAxisMappingStrategy(osr.OAMS_TRADITIONAL_GIS_ORDER)  # ask for
longitude, latitude order
layer, layer_ds = make_ogr_feature(srs, 'Polygon ((32 33,38 33,38 38,32
38,32 33))')
use_geotransform = False
if use_geotransform:
   ds.SetSpatialRef(srs)
   ds.SetGeoTransform([30,(40 - 30) / ds.RasterXSize,0,40,0, - (40 - 30)
/ ds.RasterYSize])
else:
   ds.SetGCPs([gdal.GCP(30,40, 0, 0.5, 0.5, '', 'UpperLeft'),
               gdal.GCP(40,40, 0, 99.5, 0.5, '', 'UpperRight'),
               gdal.GCP(40,30,0,99.5,99.5,'','LowerRight'),
               gdal.GCP(30,30,0,0.5,99.5, '','LowerLeft')], srs)
gdal.RasterizeLayer(ds, [1,2,3], layer, burn_values=[255,255,255])
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241218/832dd916/attachment.htm>
