[gdal-dev] Issue with Missing "gdal_MG4Lidar.dll" in GDAL 3.9.3 Build
Parveen Sharma sharma1981 at outlook.com
Thu Dec 19 19:51:30 PST 2024
Hello
I am currently building GDAL 3.9.3 using CMake with the following configuration:
I have specified below flags
<arg value="-DGDAL_BUILD_OPTIONAL_DRIVERS=ON"/>
<arg value="-DGDAL_USE_MRSID=ON"/>
<arg value="-DMRSID_LIBRARY=${unpack.dir.modified}/mrsid/Raster_DSDK/lib/lti_dsdk.lib"/>
<arg value="-DMRSID_INCLUDE_DIR=${unpack.dir.modified}/mrsid/Raster_DSDK/include"/>
The build process produces gdal_MrSID.dll, but I am not seeing the gdal_MG4Lidar.dll. Previously, with GDAL 3.3, both these DLLs were generated successfully.
I suspect the following CMake options might no longer be valid, as they seem to have no effect:
<arg value="-DMRSID_LIDAR_LIBRARY=${unpack.dir.modified}/mrsid/Lidar_DSDK/lib/lti_lidar_dsdk.lib"/>
<arg value="-DMRSID_LIDAR_INCLUDE_DIR=${unpack.dir.modified}/mrsid/Lidar_DSDK/include"/>
Could someone please clarify what might be missing or what changes are needed to generate gdal_MG4Lidar.dll in GDAL 3.9.3?
Thank you for your assistance.
Best regards,
Parveen
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241220/22b07617/attachment.htm>
