[gdal-dev] GEOTIFF with RAT - transformation unsuccessful (and related warning)
ElPaso
elpaso at itopen.it
Fri Dec 20 05:55:24 PST 2024
Il 20/12/24 12:59, Rahkonen Jukka via gdal-dev ha scritto:
> Hi,
> All GeoTIFF creation options are documented in
> https://gdal.org/en/stable/drivers/raster/gtiff.html. There is no
> creation option "CREATE_RAT=YES". There is also no configuration
> option --config RAT_PATH. Either the name of your friend is AI or they
> are hallucinating.
> The gdal_translate utility copies the RAT from the source image if it
> exists but gdal_translate cannot create RAT. If you work with GDAL the
> RAT must be written manually. Another option is to use QGIS with this
> plugin
> https://github.com/noaa-ocs-hydrography/qgis-raster-attribute-table-plugin
RAT management is now in QGIS core since version 3.30, no need to use a
plugin.
Kind regards.
Alessandro Pasotti
w3: www.itopen.it
