[gdal-dev] full projection parameters in geotiff
Even Rouault even.rouault at spatialys.com
Fri Dec 20 08:07:10 PST 2024
Kirk,
Yes if there's an EPSG code for the CRS, GDAL avoids going through
defining all the parameters. That limits the risk of self-contradicting
definitions, and readers being confused by what is authoritative.
The following (untested (TM)) patch should accomplish what you want:
diff --git a/frmts/gtiff/gt_wkt_srs.cpp b/frmts/gtiff/gt_wkt_srs.cpp
index 22eabfcd38..5a089142f8 100644
--- a/frmts/gtiff/gt_wkt_srs.cpp
+++ b/frmts/gtiff/gt_wkt_srs.cpp
@@ -2213,7 +2213,8 @@ int GTIFSetFromOGISDefnEx(GTIF *psGTIF,
OGRSpatialReferenceH hSRS,
              GTIFKeySet(psGTIF, ProjectedCSTypeGeoKey, TYPE_SHORT, 1,
nPCS);
-    else if (poSRSCompatibleOfWKT1->IsGeocentric())
+    if (poSRSCompatibleOfWKT1->IsGeocentric())
          GTIFKeySet(psGTIF, GTModelTypeGeoKey, TYPE_SHORT, 1,
                     ModelTypeGeocentric);
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
Mood of the day: "Bien entendu, on peut sauter sur sa chaise comme un cabri en disant : les standards ! les standards ! les standards ! Mais ça n’aboutit à rien et ça ne signifie rien." ~ dixit De Gaulle
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241220/6e35c89c/attachment.htm>
