[gdal-dev] Shape update/addition for Ceres
Even Rouault
even.rouault at spatialys.com
Sat Dec 21 06:40:04 PST 2024
Scott,
You don't need to depend on Esri for that:
$ gdalsrsinfo IAU_2015:200000101
PROJ.4 : +proj=longlat +a=487300 +b=446000 +no_defs
OGC WKT2:2019 :
GEOGCRS["Ceres (2015) / Ographic",
DATUM["Ceres (2015)",
ELLIPSOID["Ceres (2015)",487300,11.7990314769976,
LENGTHUNIT["metre",1]],
ANCHOR["Kait: 0.0"]],
PRIMEM["Reference Meridian",0,
ANGLEUNIT["degree",0.0174532925199433]],
CS[ellipsoidal,2],
AXIS["geodetic latitude (Lat)",north,
ORDER[1],
AXIS["geodetic longitude (Lon)",east,
ORDER[2],
ID["IAU",200000101,2015],
REMARK["Source of IAU Coordinate systems:
https://doi.org/10.1007/s10569-017-9805-5"]]
Even
Le 21/12/2024 à 15:17, Reynolds, Scott via gdal-dev a écrit :
> As a user of GDAL in some of our products I’m trying to find a
> contact, probably/possibly at Esri, that could add a new entry for
> Ceres that uses the oblate parameters defined here
> <https://astropedia.astrogeology.usgs.gov/download/Docs/WGCCRE/WGCCRE2015reprint.pdf>
> (487.3km, 446km). ESRI:104972 exists for the spherical definition (470
> km).
> Thanks,
> Scott
> Disclaimer
> The information contained in this electronic message and any
> attachments to this message are intended only for the individual(s)
> addressed in the message and may contain proprietary and confidential
> information. If you are not the intended recipient, you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> and delete this message. WARNING: Computer viruses can be transmitted
> via email. The recipient should scan this email before opening it. The
> company accepts no liability for any damage caused by any virus
> transmitted by this email.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
Mood of the day: "Bien entendu, on peut sauter sur sa chaise comme un cabri en disant : les standards ! les standards ! les standards ! Mais ça n’aboutit à rien et ça ne signifie rien." ~ dixit De Gaulle
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241221/746ed689/attachment.htm>
