[gdal-dev] Possible interlaced 16-bit grayscale PNG read error
Even Rouault
even.rouault at spatialys.com
Sat Dec 28 09:15:44 PST 2024
This should be fixed per https://github.com/OSGeo/gdal/pull/11553 . This
is indeed a 25-year old issue. An indication of how 16-bit interlaced
PNGs are popular :-)
Even
Le 28/12/2024 à 10:42, Ray at Daylon via gdal-dev a écrit :
> In GDAL 1.8.0 on little-endian platforms like x64, the PNG driver will
> not byteswap pixels from network order (big endian) to little-endian
> if the PNG is interlaced (or at least if it's 16-bit grayscale
> interlaced).
> Does anyone know if this was corrected in a future version?
> In pngdataset.cpp, PNGDataset::LoadScanline() has this code:
> if( bInterlaced )
> return LoadInterlacedChunk( nLine );
> The early return causes this downstream byteswapping section:
> if( nBitDepth == 16 )
> GDALSwapWords( row, 2, GetRasterXSize() * GetRasterCount(), 2 );
> to be skipped.
> LoadInterlacedChunk() as far as I can tell even in 3.9.2. doesn't
> do any byteswapping.
> Ray Gardener
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
