[gdal-dev] Fwd: WMTS huge difference in performance - cache issue
Michał Kowalczuk michkowalczuk at gmail.com
Tue Jul 2 00:49:31 PDT 2024
Great to hear:-)
Thank you!
Michał
pon., 1 lip 2024 o 19:13 Even Rouault <even.rouault at spatialys.com>
napisał(a):
> Michał,
> Le 01/07/2024 à 18:49, Michał Kowalczuk via gdal-dev a écrit :
> Did my email reached gdal mailing list?
> yes, it did. I just had a look
> There's indeed an issue in the WMTS driver which I've ticketed at
> https://github.com/OSGeo/gdal/issues/10348 . See bottom of the ticket for
> a workaround.
> Even
> Regards
> Michal
> ------ Wiadomość przekazana dalej ------
> Od: Michał Kowalczuk <michkowalczuk at gmail.com>
> Data: pt., 28.06.2024 o 14:59
> Temat: WMTS huge difference in performance - cache issue
> Do: <gdal-dev at lists.osgeo.org>
> Hi,
> I have two sample WMTS servers.
> The first is a Polish geoportal:
> https://mapy.geoportal.gov.pl/wss/service/WMTS/guest/wmts/G2_MOBILE_500
> and the second is German:
> https://basemap.de/dienste/wmts_capabilities_web_raster.xml
> Both work well in QGIS.
> I use C API for creating bitmaps in my area of interest.
> I use GDALDatasetRasterIO function directly with WMTS dataset and
> appropriate arguments.
> The first Polish server works smoothly for different extents, different
> widths and heights of my output image. Unfortunately, the second one
> (German) lasts forever.
> During debugging I concluded the thesis that every GDALDatasetRasterIO in
> my loop over raster lines, GDAL do not use cache but redownload the same
> tiles.
> Below is a fragment from GDAL log for well-working Polish server:
> *[Fri Jun 28 13:06:16 2024].5430, 66.7590: HTTP: Requesting [1/3]
> http://mapy.geoportal.gov.pl/wss/service/WMTS/guest/wmts/G2_MOBILE_500?service=WMTS&request=GetTile&version=1.0.0&layer=G2_MOBILE_500&style=default&format=image/png&TileMatrixSet=EPSG:2180&TileMatrix=EPSG:2180:4&TileRow=2&TileCol=0
> <http://mapy.geoportal.gov.pl/wss/service/WMTS/guest/wmts/G2_MOBILE_500?service=WMTS&request=GetTile&version=1.0.0&layer=G2_MOBILE_500&style=default&format=image/png&TileMatrixSet=EPSG:2180&TileMatrix=EPSG:2180:4&TileRow=2&TileCol=0>
> [Fri Jun 28 13:06:16 2024].5430, 66.7590: HTTP: Requesting [2/3]
> http://mapy.geoportal.gov.pl/wss/service/WMTS/guest/wmts/G2_MOBILE_500?service=WMTS&request=GetTile&version=1.0.0&layer=G2_MOBILE_500&style=default&format=image/png&TileMatrixSet=EPSG:2180&TileMatrix=EPSG:2180:4&TileRow=2&TileCol=1
> <http://mapy.geoportal.gov.pl/wss/service/WMTS/guest/wmts/G2_MOBILE_500?service=WMTS&request=GetTile&version=1.0.0&layer=G2_MOBILE_500&style=default&format=image/png&TileMatrixSet=EPSG:2180&TileMatrix=EPSG:2180:4&TileRow=2&TileCol=1>
> [Fri Jun 28 13:06:16 2024].6670, 66.8830: HTTP: Requesting [3/3]
> http://mapy.geoportal.gov.pl/wss/service/WMTS/guest/wmts/G2_MOBILE_500?service=WMTS&request=GetTile&version=1.0.0&layer=G2_MOBILE_500&style=default&format=image/png&TileMatrixSet=EPSG:2180&TileMatrix=EPSG:2180:4&TileRow=2&TileCol=2
> <http://mapy.geoportal.gov.pl/wss/service/WMTS/guest/wmts/G2_MOBILE_500?service=WMTS&request=GetTile&version=1.0.0&layer=G2_MOBILE_500&style=default&format=image/png&TileMatrixSet=EPSG:2180&TileMatrix=EPSG:2180:4&TileRow=2&TileCol=2>
> [Fri Jun 28 13:06:16 2024].8230, 67.0390: HTTP: Request [0]
> : status = 200, type = image/png, error = (null) [Fri Jun 28 13:06:16
> 2024].8230, 67.0390: HTTP: Request [1]
> 2024].8230, 67.0390: HTTP: Request [2]
> 2024].8240, 67.0400: GDAL:
> GDALOpen(/vsimem/wms/0000022663367550/wmsresult.dat, this=000002266059B0E0)
> succeeds as PNG. [Fri Jun 28 13:06:16 2024].8260, 67.0420: GDAL:
> GDALClose(/vsimem/wms/0000022663367550/wmsresult.dat,
> this=000002266059B0E0) [Fri Jun 28 13:06:16 2024].8270, 67.0430: GDAL:
> GDALOpen(/vsimem/wms/00000226632272D0/wmsresult.dat, this=000002266059B0E0)
> succeeds as PNG. [Fri Jun 28 13:06:16 2024].8300, 67.0460: GDAL:
> GDALClose(/vsimem/wms/00000226632272D0/wmsresult.dat,
> this=000002266059B0E0) [Fri Jun 28 13:06:16 2024].8300, 67.0460: GDAL:
> GDALOpen(/vsimem/wms/0000022661BEC8D0/wmsresult.dat, this=000002266059B0E0)
> succeeds as PNG. [Fri Jun 28 13:06:16 2024].8330, 67.0490: GDAL:
> GDALClose(/vsimem/wms/0000022661BEC8D0/wmsresult.dat,
> this=000002266059B0E0) *
> And here is log snippet for German server:
> *[Fri Jun 28 13:16:02 2024].0840, 652.3000: HTTP: Requesting [1/5]
> https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/0.png
> <https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/0.png>
> [Fri Jun 28 13:16:02 2024].0840, 652.3000: HTTP: Requesting [2/5]
> https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/1.png
> <https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/1.png>
> [Fri Jun 28 13:16:02 2024].2690, 652.4850: HTTP: Requesting [3/5]
> https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/2.png
> <https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/2.png>
> [Fri Jun 28 13:16:02 2024].2870, 652.5030: HTTP: Requesting [4/5]
> https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/3.png
> <https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/3.png>
> [Fri Jun 28 13:16:02 2024].3140, 652.5300: HTTP: Requesting [5/5]
> https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/4.png
> <https://sgx.geodatenzentrum.de/wmts_basemapde/tile/1.0.0/de_basemapde_web_raster_farbe/default/DE_EPSG_25832_ADV/02/0/4.png>
> [Fri Jun 28 13:16:02 2024].5970, 652.8130: HTTP: Request [0]
> : status = 200, type = image/png, error = (null) [Fri Jun 28 13:16:02
> 2024].5970, 652.8130: HTTP: Request [1]
> 2024].5970, 652.8130: HTTP: Request [2]
> 2024].5970, 652.8130: HTTP: Request [3]
> 2024].5970, 652.8130: HTTP: Request [4]
> : status = 0, type = (null), error = (null) [Fri Jun 28 13:16:02
> 2024].5970, 652.8130: GDAL:
> GDALOpen(/vsimem/wms/0000022661D59690/wmsresult.dat, this=000002266059B0E0)
> succeeds as PNG. [Fri Jun 28 13:16:02 2024].5990, 652.8150: GDAL:
> GDALClose(/vsimem/wms/0000022661D59690/wmsresult.dat,
> this=000002266059B0E0) [Fri Jun 28 13:16:02 2024].6190, 652.8350: WMS:
> Clean cache [Fri Jun 28 13:16:02 2024].6190, 652.8350: GDAL:
> GDALOpen(/vsimem/wms/000002266237A190/wmsresult.dat, this=000002266059B0E0)
> succeeds as PNG. [Fri Jun 28 13:16:02 2024].6200, 652.8360: GDAL:
> GDALClose(/vsimem/wms/000002266237A190/wmsresult.dat,
> this=000002266059B0E0) [Fri Jun 28 13:16:02 2024].6340, 652.8500: GDAL:
> GDALOpen(/vsimem/wms/0000022662340E00/wmsresult.dat, this=000002266059B0E0)
> succeeds as PNG. [Fri Jun 28 13:16:02 2024].6340, 652.8500: GDAL:
> GDALClose(/vsimem/wms/0000022662340E00/wmsresult.dat,
> this=000002266059B0E0) [Fri Jun 28 13:16:02 2024].6350, 652.8510: GDAL:
> GDALOpen(/vsimem/wms/00000226605A35B0/wmsresult.dat, this=000002266059B0E0)
> succeeds as PNG. [Fri Jun 28 13:16:02 2024].6360, 652.8520: GDAL:
> GDALClose(/vsimem/wms/00000226605A35B0/wmsresult.dat,
> this=000002266059B0E0) [Fri Jun 28 13:16:02 2024].6360, 652.8520: WMS:
> ReadBlockFromCache [Fri Jun 28 13:16:02 2024].6370, 652.8530: CPLError:
> ./gdalwmscache\76ac5c8f3010af4e1a17a26a53e6ac32/0/b/0bab9c0d45a96010ec0092c98e78a52d:
> No such file or directory ERROR 4:
> No such file or directory [Fri Jun 28 13:16:02 2024].6370, 652.8530:
> CPLError: GDALWMS: Unable to open downloaded block. ERROR 1: GDALWMS:
> Unable to open downloaded block. [Fri Jun 28 13:16:02 2024].6370, 652.8530:
> WMS: After ReadBlockFromCache [Fri Jun 28 13:16:02 2024].6370, 652.8530:
> CPLError: GDALWMS: Unable to download block 4, 0. URL:   HTTP status code:
> 0, error: (null). Add the HTTP status code to <ZeroBlockHttpCodes> to
> ignore this error (see http://www.gdal.org/frmt_wms.html
> <http://www.gdal.org/frmt_wms.html>). ERROR 1: GDALWMS: Unable to download
> block 4, 0. URL:   HTTP status code: 0, error: (null). Add the HTTP status
> code to <ZeroBlockHttpCodes> to ignore this error (see
> http://www.gdal.org/frmt_wms.html <http://www.gdal.org/frmt_wms.html>).
> [Fri Jun 28 13:16:02 2024].6370, 652.8530: CPLError: GDAL_WMS>, band 3:
> IReadBlock failed at X offset 0, Y offset 0: GDALWMS: Unable to download
> ERROR 1: GDAL_WMS>, band 3: IReadBlock failed at X offset 0, Y offset 0:
> GDALWMS: Unable to download block 4, 0. URL:   HTTP status code: 0, error:
> (null). Add the HTTP status code to <ZeroBlockHttpCodes> to ignore this
> <http://www.gdal.org/frmt_wms.html>). [Fri Jun 28 13:16:02 2024].6380,
> 652.8540: GDAL:
> GDALOpen(./gdalwmscache\76ac5c8f3010af4e1a17a26a53e6ac32/1/5/15b3159bb18ea6f97264bd4d0bac680e,
> this=000002266059B0E0) succeeds as PNG. [Fri Jun 28 13:16:02 2024].6380,
> 652.8540: GDAL:
> GDALClose(./gdalwmscache\76ac5c8f3010af4e1a17a26a53e6ac32/1/5/15b3159bb18ea6f97264bd4d0bac680e,
> this=000002266059B0E0) [Fri Jun 28 13:16:02 2024].6390, 652.8550: HTTP:
> Requesting [1/1]
> [Fri Jun 28 13:16:02 2024].8540, 653.0700: HTTP: Request [0]
> 2024].8540, 653.0700: WMS: ReadBlockFromCache [Fri Jun 28 13:16:02
> 2024].8550, 653.0710: CPLError:
> No such file or directory [Fri Jun 28 13:16:02 2024].8550, 653.0710:
> Unable to open downloaded block. [Fri Jun 28 13:16:02 2024].8550, 653.0710:
> WMS: After ReadBlockFromCache [Fri Jun 28 13:16:02 2024].8550, 653.0710:
> [Fri Jun 28 13:16:02 2024].8550, 653.0710: CPLError: GDAL_WMS>, band 3:
> <http://www.gdal.org/frmt_wms.html>). [Fri Jun 28 13:16:02 2024].8560,
> 653.0720: GDAL:
> this=000002266059B0E0) succeeds as PNG. [Fri Jun 28 13:16:02 2024].8560,
> 653.0720: GDAL:
> this=000002266059B0E0) [Fri Jun 28 13:16:02 2024].8570, 653.0730: HTTP:
> Requesting [1/1]
> [Fri Jun 28 13:16:03 2024].0760, 653.2920: HTTP: Request [0]
> : status = 0, type = (null), error = (null) [Fri Jun 28 13:16:03
> 2024].0760, 653.2920: WMS: ReadBlockFromCache [Fri Jun 28 13:16:03
> 2024].0760, 653.2920: CPLError:
> No such file or directory [Fri Jun 28 13:16:03 2024].0760, 653.2920:
> Unable to open downloaded block. [Fri Jun 28 13:16:03 2024].0760, 653.2920:
> WMS: After ReadBlockFromCache [Fri Jun 28 13:16:03 2024].0760, 653.2920:
> [Fri Jun 28 13:16:03 2024].0760, 653.2920: CPLError: GDAL_WMS>, band 3:
> <http://www.gdal.org/frmt_wms.html>).*
> How you see, GDAL tries to open cache that does not exist.
> But in fact, it exist. I found all necessary tile for full extent map
> request in gdalwmscache folder.
> I can not send it in this email because of message size limits.
> Regards,
> Michał
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240702/a67646ba/attachment-0001.htm>
