[gdal-dev] Issues specifying PostGIS connection details - possibly related to special characters in passwords?
Daniel Evans
daniel.fred.evans at gmail.com
Tue Jul 2 09:08:01 PDT 2024
Hi Robin,
Is this a shell issue, rather than a GDAL one? The dollar sign makes me
suspect that a Unix shell is interpreting "robin$42" as "the string 'robin'
and the value of variable $42" before it gets into GDAL. My terminal would
interpret it as the following:
$ echo robin$42
robin
and I'd need to escape the dollar symbol to get the text verbatim:
$ echo robin\$42
robin$42
Cheers,
Daniel
On Tue, 2 Jul 2024 at 16:35, Robin Wilson via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> I’m using ogr2ogr to load a GeoPackage file into a PostGIS database. I
> initially tried using a command like this:
> ogr2ogr --debug ON -f PostgreSQL PG:"host=<IP> user=<user>
> password=robin$42 dbname=data sslmode=require" file.gpkg -nln table_name
> However, this doesn’t work, and I always get an error:
> FATAL: password authentication failed for user “<user>"
> If I restructure the command to use the alternative postgresql://
> connection string like this, then it works:
> ogr2ogr --debug ON -f PostgreSQL 'postgresql://<user>:robin$42@<IP>/data?sslmode=require’
> I don’t remember running into this problem before when connecting to
> PostGIS databases using the PG: connection string, so I’m wondering whether
> my shell is doing something strange with my password? Obviously I don’t
> want to share my actual password, but it has a $ in it, and I wonder
> whether somehow this is causing problems - but only when using the PG:
> connection string.
> Any suggestions welcome,
> Best regards,
> Robin
> Dr Robin Wilson
> www.rtwilson.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240702/424b66dd/attachment.htm>
