[gdal-dev] Issues specifying PostGIS connection details - possibly related to special characters in passwords?
Daniel Evans
daniel.fred.evans at gmail.com
Tue Jul 2 09:15:42 PDT 2024
I think the trick there is that single quotes make most shells consider a
string verbatim - I'd forgotten that part! That's probably the more
desirable solution, actually.
Cheers,
Daniel
On Tue, 2 Jul 2024, 17:13 Robin Wilson, <robin at rtwilson.com> wrote:
> Hi,
> Hmm, I’m sure I tried escaping it before - but putting a \ in front of it
> fixed it - obviously I didn’t try properly before. Possibly I only tried
> quoting it in various ways. Thanks for the solution!
> Now the thing I’m intrigued about is why it was working with the
> postgresql:// connection string but not the PG connection string…
> Best regards,
> Robin
> On 2 July 2024 at 17:08:18, Daniel Evans (daniel.fred.evans at gmail.com)
> wrote:
> Hi Robin,
> Is this a shell issue, rather than a GDAL one? The dollar sign makes me
> suspect that a Unix shell is interpreting "robin$42" as "the string 'robin'
> and the value of variable $42" before it gets into GDAL. My terminal would
> interpret it as the following:
> $ echo robin$42
> robin
> and I'd need to escape the dollar symbol to get the text verbatim:
> $ echo robin\$42
> robin$42
> Cheers,
> Daniel
> On Tue, 2 Jul 2024 at 16:35, Robin Wilson via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
>> Hi,
>> I’m using ogr2ogr to load a GeoPackage file into a PostGIS database. I
>> initially tried using a command like this:
>> ogr2ogr --debug ON -f PostgreSQL PG:"host=<IP> user=<user>
>> password=robin$42 dbname=data sslmode=require" file.gpkg -nln table_name
>> However, this doesn’t work, and I always get an error:
>> FATAL: password authentication failed for user “<user>"
>> If I restructure the command to use the alternative postgresql://
>> connection string like this, then it works:
>> ogr2ogr --debug ON -f PostgreSQL 'postgresql://<user>:robin$42@<IP>/data?sslmode=require’
>> I don’t remember running into this problem before when connecting to
>> PostGIS databases using the PG: connection string, so I’m wondering whether
>> my shell is doing something strange with my password? Obviously I don’t
>> want to share my actual password, but it has a $ in it, and I wonder
>> whether somehow this is causing problems - but only when using the PG:
>> connection string.
>> Any suggestions welcome,
>> Best regards,
>> Robin
>> Dr Robin Wilson
>> www.rtwilson.com
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240702/a033d506/attachment.htm>
