[gdal-dev] ogrinfo behaviour with -al and -json options
Andrea Giudiceandrea
andreaerdna at libero.it
Tue Jul 2 22:25:16 PDT 2024
Hi all,
IIUC, the documentation states that with the -al option, ogrinfo should
output the info of all layers in a container (e.g. a GPKG file). Anyway,
when a layer name is provided in the command line string alongside the
-al option, than it looks like the -al option is overridden and not
taken in consideration.
Is this the expected behaviour?
The same behaviour occurs with the -json option, where the documentation
states than in such case the -al option is also implicit.
If those are the correct and expected behaviour, maybe it would be
useful to clarify it in the documentation.
Regards.
Andrea
