[gdal-dev] [EXTERNAL] [BULK] Re: GetPoint API listing
Even Rouault
even.rouault at spatialys.com
Mon Jul 8 13:17:11 PDT 2024
The doc for the OGRSimpleCurve class, which is the parent class of
OGRLineString, where addPoint / setPoint are defined, was missing in
that page. Should appear online in ~ 1 hour or so.
The Doxygen output at https://gdal.org/doxygen/classOGRLineString.html
might be easier to navigate.
Le 08/07/2024 à 21:59, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] via gdal-dev a écrit :
> I am on desktop. Using OGRLineString as an example, I see no
> relationship in the docs that connect it to addPoint or vise versa.
> https://gdal.org/api/ogrgeometry_cpp.html#classOGRLineString
> After faffing about a bit, no hyperlinks appear to go beyond the
> *cpp_html document. So I’m not quite sure how to interpret your
> directions.
> *From: *Laurențiu Nicola <lnicola at dend.ro>
> *Date: *Monday, July 8, 2024 at 3:29 PM
> *To: *Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS
> INC] <jesse.r.meyer at nasa.gov>, gdal-dev at lists.osgeo.org
> <gdal-dev at lists.osgeo.org>
> *Subject: *Re: [EXTERNAL] [BULK] Re: [gdal-dev] GetPoint API listing
> *CAUTION:*This email originated from outside of NASA. Please take
> care when clicking links or opening attachments. Use the "Report
> Message" button to report suspicious messages to the NASA SOC.
> Sure, click on OGRGeometry, then on a derived class (but those only
> seem to show up on desktop).
> Laurentiu
> On Mon, Jul 8, 2024, at 22:15, Meyer, Jesse R. (GSFC-618.0)[SCIENCE
> SYSTEMS AND APPLICATIONS INC] wrote:
> Thanks!
> Are these methods discoverable at the docs listing “C++ API”
> landing page under “Vector API”?
> https://gdal.org/api/index.html
> Best,
> Jesse
> *From: *gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of
> Laurențiu Nicola via gdal-dev <gdal-dev at lists.osgeo.org>
> *Date: *Monday, July 8, 2024 at 3:12 PM
> *To: *gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject: *[EXTERNAL] [BULK] Re: [gdal-dev] GetPoint API listing
> Hi,
> You can find methods like addPointand getPointin the derived
> geometry classes like
> https://gdal.org/doxygen/classOGRLineString.html#a49c349d567436a1101017b1e71771ba3.
> Laurentiu
> On Mon, Jul 8, 2024, at 21:57, Meyer, Jesse R.
> (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev wrote:
> Hi,
> When looking up documentation for OGR vector operations like
> AddPoint, they pop right up in the vector_c_api.html, but
> after digging for about 10 minutes, and through the API
> tutorial section, I could find no reference to the equivalent
> function for C++.
> Where might I find them?
> Best,
> Jesse
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240708/6419b01d/attachment-0001.htm>
