[gdal-dev] Moving from GDAL 2.2.3 to GDAL 3.4.1
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Tue Jul 9 08:33:39 PDT 2024
Please ignore this query. It turns out the new version of NASA OCSSW software is the issue. It has multiple values near -32768 that is no data. I cleaned up the file with gdal_calc and things seem to be working ok now.
Thanks,
  -Steve W
Sent from my iPhone
> On Jul 7, 2024, at 10:14 PM, Stephen Woodbridge <stephenwoodbridge37 at gmail.com> wrote:
> Hi all,
> I’m migrating some apps from Ubuntu 18.04 to Ubuntu 22.04 which means from GDAL 2.2.3 to GDAL 3.4.1.
> I having problems rendering so tiff files that go through a couple of VRT files before getting rendered via mapserver.
> Sorry there are a lot of moving pieces and I’m trying to narrow down where I should be looking for a problem. I wondering if there were changes in the VRT file system. I can display other files with a problem.
> I have a directory of a days worth of SST tiff files. The first VRT collects all these into a single file. The second VRT then applies a color table to the first VRT.
> I can post an example if that would help. The works on 18.04 but not 22.04.
> Thoughts?
> Steve W
> Sent from my iPhone
