[gdal-dev] GDAL 3.7.0 Proj 6.3.1 strange behavior when performing NAD83(EPSG:4152) to NAD83 HARN(EPSG:4269) realization transformation
Even Rouault
even.rouault at spatialys.com
Mon Jul 15 09:30:11 PDT 2024
Support for US datum transformations has been vastly improved in PROJ
9.2.0 with NADCON5 grid based transformations
Le 15/07/2024 à 17:46, David Klaus via gdal-dev a écrit :
> Greg,
> Thank you for that information. I will post my example code shortly.
> Hopefully there is an obvious mistake in my code that is not related
> to Proj4 or GDAL version,
> On Mon, Jul 15, 2024 at 11:40 AM Greg Troxel <gdt at lexort.com> wrote:
> David Klaus <dklaus at carlsonsw.com> writes:
> > As far as upgrading Proj4; because we build Proj4 statically in
> our custom
> > build, it's not a trivial task to upgrade versions. Also, I
> think there
> > might be compatibility reasons why we've stuck with 6.3.1 up
> until now.
> > But if NAD83 realization transformation functionality has been
> expanded and
> > improved in later versions, it might be worth it for us to
> upgrade. I was
> > wondering, judging by the contents of the proj-datumgrid
> packages I've
> > found online, it looks like Proj4 did not support any NAD83
> realization
> > transformations besides 1986->HARN before at least Proj4 7.0.
> I maintain an unrelated (not geo) software package, and there my
> practice is not to engage in debugging old versions. It takes a
> lot of
> time and in the cases the problem has been resolved already, it is
> entirely not useful (to the project).
> I am not saying NAD83 is better specifically if you udpate. I really
> don't know.
> David Klaus
> Carlson Software
> *Disclaimer*
> The information contained in this communication from the sender is
> confidential. It is intended solely for use by the recipient and
> others authorized to receive it. If you are not the recipient, you are
> hereby notified that any disclosure, copying, distribution or taking
> action in relation of the contents of this information is strictly
> prohibited and may be unlawful.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240715/ede78570/attachment.htm>
