[gdal-dev] Documentation/explanation on repository structure
Even Rouault
even.rouault at spatialys.com
Mon Jul 15 10:05:11 PDT 2024
hopefully this proposed improvement of the developer doc
https://github.com/OSGeo/gdal/pull/10427 should answer your questions
Even
Le 14/07/2024 à 21:57, Thomas Larsen Wessel via gdal-dev a écrit :
> It's hard for me to understand the structure of the repository. Is
> there any documentation on this?
> For instance. I see python scripts (able to be run from command line,
> not just modules/packages) in a few places:
> ./scripts
> ./swig/python/gdal-utils/scripts
> ./swig/python/gdal-utils/osgeo_utils
> ./swig/python/gdal-utils/osgeo_utils/auxiliary
> ./swig/python/gdal-utils/osgeo_utils/samples
> I don't see/understand the structure. But maybe, with some help, I could?
> To be concrete, lets consider validate_gpkg.py. Why is it in
> "samples", and not in any of the others? Why does it belong in that
> folder?
> Some scripts seem to be in more than one place (though not identical,
> at least not in formatting) e.g.:
> - ./swig/python/gdal-utils/scripts/gdal2tiles.py
> - ./swig/python/gdal-utils/osgeo_utils/gdal2tiles.py
> Is there any documentation that will help me understand the structure,
> including the questions above?
> Sincerely, Thomas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
