[gdal-dev] GDAL 3.7.0 Proj 6.3.1 strange behavior when performing NAD83(EPSG:4152) to NAD83 HARN(EPSG:4269) realization transformation
David Klaus dklaus at carlsonsw.com
Mon Jul 15 10:30:28 PDT 2024
All,
If I understand correctly. Before we do anything else, we should try to
rebuilt our GDAL solution such that it uses at least Proj4 9.2.0, do I have
that right? Does anyone happen to know the minimum GDAL version compatible
with Proj4 9.2.0?
P.S. I am still working on the code example to repeat the issue I ran into.
On Mon, Jul 15, 2024 at 1:03 PM Greg Troxel <gdt at lexort.com> wrote:
> David Klaus <dklaus at carlsonsw.com> writes:
> > Thank you for the input. You don't happen to know where I can find
> > documentation on these NADCON5 related changes?
> I would suggest reading the 9.2.0 release notes.
> There is a link to a merged PR which has further discussion.
> The tl;dr; is that proj matches NGS tools.  Which is a pretty stunning
> result.
David Klaus
Carlson Software
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240715/30ad2ee1/attachment.htm>
