[gdal-dev] Problems compiling the project
Abel Pau a.pau at creaf.cat
Fri Jul 19 07:30:01 PDT 2024
Hi Even,
I tried at some point using the --config Debug option.
It makes no difference.
I don’t understand the difference between now and some months ago.
I’ll keep looking for a solution.
Thanks!
De: Even Rouault <even.rouault at spatialys.com>
Enviado el: dijous, 18 de juliol de 2024 12:17
Para: Abel Pau <a.pau at creaf.cat>; gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Problems compiling the project
Hi Abel,
the error message indicates that the build is trying to link a release version of poppler.lib, whereas your build is a debug one.
For multi-config generators like Visual Studio builds, I'm not sure how -DCMAKE_BUILD_TYPE=Debug is effective. You perhaps need to do the following instead:
cmake --build build --config Debug
Even
Le 17/07/2024 à 17:59, Abel Pau via gdal-dev a écrit :
I’m trying to compile the project using the two lines that always have worked:
cmake -B build -S . -DCMAKE_TOOLCHAIN_FILE=C:/dev/vcpkg/vcpkg/scripts/buildsystems/vcpkg.cmake -DCMAKE_BUILD_TYPE=Debug
cmake --build build
Before starting I deleted the build folder.
The first line is ok and creates the projects... but the second one gives me some red errors.
I’m using windows and Visual Studio 2019
Is there something I’m missing?
Thanks!
Generating Code...
  shapelib.vcxproj -> D:\GitHub-repository\gdal\build\ogr\ogrsf_frmts\shape\shapelib.dir\Debug\shapelib.lib
  Building Custom Rule D:/GitHub-repository/gdal/CMakeLists.txt
poppler.lib(Error.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2
' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Error.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match
value 'MDd_DynamicDebug' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Object.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '
2' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Object.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't matc
h value 'MDd_DynamicDebug' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Catalog.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value
'2' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(Catalog.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't mat
ch value 'MDd_DynamicDebug' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
poppler.lib(XRef.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2'
poppler.lib(XRef.obj) : error LNK2038: mismatch detected for 'RuntimeLibrary': value 'MD_DynamicRelease' doesn't match
poppler.lib(OptionalContent.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't matc
h value '2' in cpl_alibaba_oss.obj [D:\GitHub-repository\gdal\build\GDAL.vcxproj]
Abel Pau Garcia
[https://www.creaf.cat/sites/default/files/logo-creaf-small.jpg]<https://www.creaf.cat/>
GIS developer
a.pau at creaf.uab.cat <mailto:a.pau at creaf.uab.cat>
[https://www.creaf.cat/sites/default/files/cap_0.png]
Let's chat on Teams! <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
Tel. +34 934814277
[https://www.creaf.cat/sites/default/files/x_30.png]<https://twitter.com/CREAF_ecologia>[https://www.creaf.cat/sites/default/files/linkedin_30.png]<https://www.linkedin.com/company/creaf/>[https://www.creaf.cat/sites/default/files/youtube_30.png]<https://www.youtube.com/c/creafecologia>[https://www.creaf.cat/sites/default/files/instagram_30.png]<https://www.instagram.com/CREAF_ecologia/>
www.creaf.cat <http://www.creaf.cat> | http://blog.creaf.cat
CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona) <https://www.openstreetmap.org/way/123379060>
Política de privacitat <https://www.creaf.cat/ca/politica-de-privacitat>
[https://www.creaf.cat/sites/default/files/corner_right_0.png]
Abans d'imprimir aquest missatge electrònic penseu en el medi ambient.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240719/161a0faf/attachment-0001.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240719/161a0faf/attachment-0001.jpg>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240719/161a0faf/attachment-0006.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240719/161a0faf/attachment-0007.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240719/161a0faf/attachment-0008.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240719/161a0faf/attachment-0009.png>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240719/161a0faf/attachment-0010.png>
Type: image/png
Desc: image007.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240719/161a0faf/attachment-0011.png>
