[gdal-dev] Extracting data from a parquet file
Even Rouault even.rouault at spatialys.com
Mon Jul 22 12:29:35 PDT 2024
Le 22/07/2024 à 21:10, Joaquim Manuel Freire Luís a écrit :
> Even,
> Thanks for the explanation. But how did you find the name of the
> geometries (geo_point_2D and geo_shape)? Loading the
> “world-administrative-boundaries.parquet” in a binary editor I can see
> them there, but that’s certainly not the way to find these things.
$ ogrinfo world-administrative-boundaries.parquet -al -so | grep
"Geometry Column"
Geometry Column 1 = geo_point_2d
Geometry Column 2 = geo_shape
> Joaquim
> *From:*Even Rouault <even.rouault at spatialys.com>
> *Sent:* Monday, July 22, 2024 2:29 PM
> *To:* Joaquim Manuel Freire Luís <jluis at ualg.pt>; gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Extracting data from a parquet file
> Joaquim,
> The GeoPackage format only supports one geometry field per layer. and
> the QGIS OGR provider doesn't know currently how to handle several
> geometry fields per layer too
> To do what you want, you need to explictly select the desired geometry
> field name with:
> ogr2ogr out.gpkg world-administrative-boundaries.parquet -sql "select
> geo_shape, * from \"world-administrative-boundaries\""
> Actually if you outputted to a format that supports several geometry
> fields per layer (let's say PostGIS), the above wouldn't work. You
> would need to exclude the geometry fields from the wildcard *
> selection with:
> geo_shape, * exclude (geo_point_2D, geo_shape) from
> Even
> Le 19/07/2024 à 16:58, Joaquim Manuel Freire Luís via gdal-dev a écrit :
>     Hi,
>     I finally managed to build a working GDAL with the arrow/parquet
>     driver and I’m now trying to convert this file
>     (https://public.opendatasoft.com/api/explore/v2.1/catalog/datasets/world-administrative-boundaries/exports/parquet?lang=en&timezone=Europe%2FLondon
>     <https://public.opendatasoft.com/api/explore/v2.1/catalog/datasets/world-administrative-boundaries/exports/parquet?lang=en&timezone=Europe%2FLondon>)
>     but can only extract the “Point”, not the “Multi polygon”
>     INFO: Open of `world-administrative-boundaries.parquet'
>           using driver `Parquet' successful.
>     1: world-administrative-boundaries (Point, Multi Polygon)
>     This gets only the points
>     ogr2ogr lixo.gpkg world-administrative-boundaries.parquet
>     The same happens if I open the file in QGis. Points only, no polygons.
>     But if I do an ogrinfo -al, it prints all data in file.
>     ogrinfo -al world-administrative-boundaries.parquet
>     OGRFeature(world-administrative-boundaries):255
>       iso3 (String) = GIB
>       status (String) = UK Non-Self-Governing Territory
>       color_code (String) = GBR
>       name (String) = Gibraltar
>     So, how can we select in ogr2ogr to extract the polygons?
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240722/58cef890/attachment-0001.htm>
