[gdal-dev] Building GDAL documentation with ReadTheDocs
Daniel Baston dbaston at gmail.com
Tue Jul 23 09:14:40 PDT 2024
Hello,
I've put together a configuration to build GDAL's documentation using
ReadTheDocs. As far as I know, this is the simplest way of publishing
version-specific documentation and rending documentation for pull
requests. A current build of the documentation can be viewed at
https://gdal.readthedocs.io/en/latest/. A pull request with the
proposed configuration is available at
https://github.com/OSGeo/gdal/pull/10434.
If anyone has feedback about using ReadTheDocs for this project, or
the specifics of the proposed configuration, please share it here or
as a comment on the pull request.
Thanks,
Dan
