[gdal-dev] Building GDAL documentation with ReadTheDocs
Even Rouault
even.rouault at spatialys.com
Tue Jul 23 10:28:47 PDT 2024
Le 23/07/2024 à 19:18, Greg Troxel via gdal-dev a écrit :
> Daniel Baston via gdal-dev<gdal-dev at lists.osgeo.org> writes:
>> Hello,
>> I've put together a configuration to build GDAL's documentation using
>> ReadTheDocs. As far as I know, this is the simplest way of publishing
>> version-specific documentation and rending documentation for pull
>> requests. A current build of the documentation can be viewed at
>> https://gdal.readthedocs.io/en/latest/. A pull request with the
>> proposed configuration is available at
>> https://github.com/OSGeo/gdal/pull/10434.
>> If anyone has feedback about using ReadTheDocs for this project, or
>> the specifics of the proposed configuration, please share it here or
>> as a comment on the pull request.
> I agree that version-specific doc publication and docs on PRs is nice.
> With things that feel like hosted services, I always want to ask:
We already had that discussion when PROJ migrated to RTD hosting last
year. So
https://lists.osgeo.org/pipermail/proj/2023-February/010919.html should
equally apply
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240723/d8b62e0e/attachment.htm>
