[gdal-dev] Expected runtime of polygonize (GDAL 3.9.0) for few very large features.
Even Rouault even.rouault at spatialys.com
Tue Jul 23 12:00:32 PDT 2024
I've got a chance to have a look at your test dataset. In
https://github.com/OSGeo/gdal/pull/10477, I've reduced the runtime to 8
minutes (with GeoParquet output, without spatial sorting), by optimizing
some implementation details. I believe this could be further reduced as
most of the time is still spent in malloc/free of temporary objects (the
output is 90 million polygons!) and some objects could be reused, but
that would be more extensive changes
Even
Le 01/07/2024 à 18:40, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] via gdal-dev a écrit :
> Hi,
> We’ve encountered a few images with what seems like pathological
> performance problems with polygonise. The details below are a report
> from another developer that I haven’t yet independently verified.
> We threshold a raster image to a binary mask in a memory dataset, use
> that as its own mask to mask out the background.
> gdal.Polygonize(nn_mem_band, nn_mem_band, ogr_mem_lyr, -1)
> We have a number of 32k x 32k raster images that feature number of
> very large same-valued regions (some as large as 80% of the entire
> raster).  We’re seeing ~10hrs on a modern workstation to complete the
> line of code above.  OpenCV can apparently construct a connected
> components list in mere seconds, on the same workstation and image, so
> we’re considering constructing the OGR geometries directly from those
> as a temporary work around.
> Is this situation a known pitfall with the current algorithm / data
> structures behind Polygonize?
> I’m able to share the problematic tile(s) if of interest,
> Best
> Jesse
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240723/6f7544c7/attachment.htm>
